parts needed for a carbed lsx swap
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
i wanna start to swap in a lsx in my 89 formy but i wanna go carb..i know i must get-
motor/4l60e combo
edebrock ls1 swap package includes msd box for ignition the coils/carb style intake
coversion torque arm
conversion motor mounts and tranny cross member
conversion headers
maybe the the fuel lines??
if theres anything else i forgot or missed..please tell thx
motor/4l60e combo
conversion headers
Transmission: 4L80E/4L80E
I think what you'd be missing is the benefits of EFI.
Carb on LSx or LTx is, in my opinion, all pain no gain.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: parts needed for a carbed lsx swap
don't buy the edelbrock msd package, buy the msd 6010 box separate so you can program your own timing curves/total timing into the box. The edelbrock box sucks in comparison.
Carb on LSx is the way to make more power than messing with super expensive EFI intakes. Not to mention you can lean out a carb for gas mileage, then pop in bigger jets and make some all out passes. Plus there is no $400-600 tune needed after every mod or cam swap.
But, the parts needed to make the carb swap will cost more than upgrade parts to EFI. So, where's the savings?
Plus, if you're paying $400-$600 for each EFI tune, you've got more money than brains. I know people like that, personally I'm not one of them and don't even hang out with them. There's more than enough help available on line to handle EFI tuning without paying a shop to do it.
Car: 89 Formy
Transmission: A4
thx for the info guys....is there anything im missiing for the swap
also...would the Vic Jr ls1 intake fit under the stock(formula) hood
Fit the engine, or fit under the hood?
I still don't see the attraction to this.
Car: 1984 Z28
bigger injectors, a fast 90 throttle body and intake, etc all add up to much more than a carb swap ever would especially if you already have the carb and fuel system setup. I honestly don't see a reason to run EFI on it.
unless you want to run BIG RPM all the time go with the performer RPM. It's shorter and a dual-plane that will work GREAT up to around 6500. Also, the MSD box that uses the pills works fine(don't let anyone tell you otherwise) I've got one(for sale) but decided to go with the 6010 because I'm going to spray my motor and want the timing retard I can put in with the laptop. The carbed motors make HUGE power and still look plenty cool. Hardcore EFI guys just don't understand!!
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Show me a carbed LSx motor that makes 500hp to the wheels, and still gets 30mpg on the highway running 4.10 gears and I'll never say another word about it.
Car: 1984 Z28
It's only a primary jet size swap from excellent mileage, in fact you can run LEANER on a carb since you're not limited to 14.7:1 I've seen some on ls1tech running 16:1 around town. I don't see any getting 30mpg though with heads and a big cam and 4:10s. Maybe a 6 speed will get close but definitely not an auto.
Car: 1987 GTA
4th gen T/A running LS1 with pretty good size cam and ported heads making 500 to the wheels (seen the dyno sheet) runs mid 6's in the 1/8th and gets 30mpg on the highway with the cruise and a/c running.
And yes, it's a 6-speed
There's no such thing as a Z07
and I would never run an LS1 at 16:1, that's just getting really stupid.
wow, I'd have to agree with the 16:1. Still doubt the credibility of 30mpg with a 500hp LS motor. Basic physics won't even allow that to happen! I can see 22-25 MAYBE...but 30? Nah....
