LS2- CARB swap-W/out wiring
Old Jan 7, 2009 | 07:38 PM
85camarojunkie's Avatar
Car: Camaro coupe
I just picked up a 05 GTO 6.0 motor for nothing. Had a rod knocking, so im going to rebuild it.
I picked it up with no intake or heads, so what im wondering is after i get a set of factory or maybe slightly ported heads. If i can put a carbed intake on it (ive seen several) to just throw it in like that. How much wiring is involved and would i still need a CPU for that model motor. I read something about using a ford dissy or something a while back, just not for sure what it was.
If anyone understands what im trying to do, please chime in. can i make it simple as a normal old chev motor.
Old Jan 7, 2009 | 10:20 PM
ljnowell's Avatar
Re: LS2- CARB swap-W/out wiring
I have a hunch that you will find that free block will cost you more in the long run that a take out engine will. AFAIK you will need to use the stock coil near plug setup of the LS engines. Edelbrock makes a kit that comes with a carb intake and a (I believe msd built) controller that runs the ignition. You will need a harness though, I dont think the kits come with one (at least they didnt when I looked at them). I would imagine that by the time you spend the money on rebuilding the shortblock, buying heads, a harness, coils, the intake kit, carb, and necessary sensors, you may find that you were money ahead buying a takeout. All this really is speculation though, depending on what you have in your garage already laying around and what you can source parts for at your local yards.
Old Jan 7, 2009 | 10:57 PM
Car: Camaro coupe
I do know people with good discounts. Im going to keep looking for a kit but if you find one could you redirect me. I figured that i would need to use factory coil setup i just wondered if there was an aftermarket setup kinda like a distributor to make it run. I dont completely understand alll about these motors, i just wanted to carb it and throw it in. Plus with carb i wouldnt need a to run new fuel lines and a new fuel pump and all.
This isnt a weekend thing, i planned on it takin several months to build. I just need info and all.
Old Jan 8, 2009 | 12:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'd probably be better off getting a complete LSx engine/harness/PCM and put your rebuilt LS2 shortblock under it.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
tero
Aug 15, 2015 02:47 PM
