Good low end cam??
Old Jan 26, 2009 | 05:46 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Good low end cam??
Hey guys i dont really go that fast but i want a cam that will make me go
0-80 real fast. Iv been told to get the cc306 but iv been told it takes alot of the low end away and i like having the power? But if it dosent then i think i want the cc306. Let me know please.
thanks
kevin
Old Jan 26, 2009 | 05:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are we talking about an LTx or LSx here, or an LO3?
Old Jan 26, 2009 | 05:59 PM
Re: Good low end cam??
We are talking about the LT1 from a 96. sorry about that. Some one said something about the Lingenfelter 211/219? seems like that would be a fun cam? But i do want something better than the hot cam that everyone has or atleast seems like.
thanks
kevin
Old Jan 26, 2009 | 06:43 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
If you want low to mid I'd go with the crane 227. BTW you can do 0-80 real fast with out a cam.
Old Jan 26, 2009 | 06:50 PM
Not really its a 96 out of a impala ss. 260hp and 330tq. I have looked that cam up the Crane 227(214/224 duration). I wanted something alittle bigger and aggresive. I didnt know how aggressive this cam was Lingenfelter 211/219?
thanks
kevin
Old Jan 26, 2009 | 07:02 PM
Car: 1992 camaro
Axle/Gears: 3:73
Well I have the cc503 that might be up FS. BTW the 227 held the "cam only" record for quite some time.
Old Jan 26, 2009 | 09:46 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
CC224/230, CC305 both can be had had thunderracing.com or summit etc..
Look here also http://www.elliottsportworks.com/lt1.html
Old Jan 26, 2009 | 10:37 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Originally Posted by GoodlookinRS
Not really its a 96 out of a impala ss. 260hp and 330tq. I have looked that cam up the Crane 227(214/224 duration). I wanted something a little bigger and aggressive.
Well, you can have "a good low-end cam" or you can have "a big cam". Generally speaking, it takes more duration to produce more lift, & more duration moves the optimal powerband higher in the RPM range.
You'd probably be best off by putting all of your info into this sucker & clicking 'submit'...
Old Jan 27, 2009 | 03:03 AM
How about this cam has anyone have it?
228/235 .560/.560 109 LSA. - 1900-6200 RPM
NON-EMISSIONS version of 224/230 cam mentioned above. Mild to choppy idel. Good HP/TQ through out and a very usable power band. Best choice for "most people" using stock bottom end. Minimum 2800 stall and 3.42 gears for B body. Comparable to Comp 467 XFI cam.
kevin
Old Jan 27, 2009 | 01:53 PM
Well here are some cams that i might go with. I guess i will have alittle poll to see which top 3 would be the best performer all the way around.
List
cc306 (to big i think)
Hot cam
crane 227
cc503
cc305
cc224/230
cc501
thanks
kevin
Old Jan 27, 2009 | 03:35 PM
Car: 1992 camaro
Axle/Gears: 3:73
kevin
You might be better off with a custom.
Old Jan 27, 2009 | 11:02 PM
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
I would go with the cc503 cam. My buddy swapped in a 96 Caprice LT1 into his 79 Monte Carlo. I has the normal bolt-ons, cc503 cam, 918 springs and 1.6 roller rockers and puts down 327rwhp. He also runs 12.84 in the 1/4. He loves that cam so far on stock cast iron heads, but make sure to upgrade the springs.
Old Jan 28, 2009 | 04:39 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Something a lot of people forget is that these are big v8 engines. They will make quite a bit of low end simply by design alone. Instead of saying "I want as much low end torque as possible", plan out exactly what you are going to do with the car. No one races from 0-80. Be specific so you don't end up building something that doesn't perform any better than a stock setup.
Old Jan 29, 2009 | 07:22 AM
Let me ask you guys just to see what you think if i go with this set up will it be fun and pretty fast like mid to low 12's?
1 Good complete rebuild .30 over
2 shorty headers, y-pipe, flowmasters
3 3000 stall converter
4 Good tune/ chip
5 Lingenfelter 211/219 cam
6 3:73 posi
7 700r4 high performance **** kit w/ corvette servo
thanks
kevin
Old Jan 29, 2009 | 05:49 PM
Car: 1992 camaro
Axle/Gears: 3:73
All looks good except #7 do your self a favor and get the 4L60E.
You can take the HotCam and get a third gen in to 12's.
Old Jan 29, 2009 | 07:22 PM
Yes i know the 700r4 isn't going to hold much but i cant afford a new trans to lol. Then the 10 bolt also. Lingenfelter 211/219 cam is bigger and better than the hot cam? atleast that was wat i was told.
thanks
kevin
Old Jan 29, 2009 | 08:10 PM
Car: 1992 camaro
Axle/Gears: 3:73
Yea it is but IIRC there where a few on here or cz28 that hit 12's with the HC. Not the best choice (HC)but I think it will get into the 12's.
Old Jan 29, 2009 | 09:31 PM
See im so confuesed what i should go with. I am just going to go to engine shops around me and see what they say and get price checks on puting it in.
kevin
Old Jan 30, 2009 | 01:27 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Contact some sponsors on ls1tech or cz28.com. They will set you up with exactly what you need. I would talk to Advanced Induction as they have put together some seriously fast combinations. Even just a custom grind cam from them would be better than the crap you can get off the shelf. If you are short on cash after the swap, spend a little and get some fbody heads (you said its an impala lt1), and put some new springs and 1.6 roller rockers on them. Put the engine in with the stock cam just like that and save up until you can get the money for a new top end. Don't waste your time with the 211/219 or the hot cam. Both are antiquated designs and there are MUCH better alternatives out there.
Contact Advanced induction or another shop like them that has PROVEN results.
Old Jan 30, 2009 | 03:21 PM
Car: 1992 camaro
Axle/Gears: 3:73
They are much better designs out ther but for what he wants to spend. I would go with a shelf cam till I had the setup I wanted and then call AI or LE.
Old Feb 2, 2009 | 01:18 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Yes but then you will be spending even more money and doing the same job twice.
With the proper bolt ons and tuning, the lt1 will make quite a bit more power than what he is used to and definitely won't have a 0-80mph problem. I still say the best advice would be to do all the bolt ons first, then tune it, then look into cams later on when he can afford to do an entire top end.
Old Feb 2, 2009 | 04:10 PM
Car: 1992 camaro
Axle/Gears: 3:73
Yea if I had it to do again I would do it again I would do a whole topend H/C package from AI or LE. But by as many questions that he has he really dont know witch way he wants to go. Witch is ok better off to ask questions than to waste money on stuff that wont work together.
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
mizz0313
Aug 12, 2015 06:45 AM
