just some info on weights on different engine combo's
Old Jan 29, 2009 | 03:19 PM
DooSPX's Avatar
I thought you guys would be interested in know these weights.
1989 L98: corvette/f-body aluminum heads:
Total Dressed Engine Mass (Dry Weight) -
Automatic Trans: 541.2 lbs (245.5 kg)
Manual Trans: 592.2 lbs (268.6 kg)
LT1:
576.4lbs dressed and dry
For the LS1 and LS6:
LS1 Total Dressed Engine Weight: Auto. - 457.6 lbs. (208 kg); Manual - 497.2 lbs (226 kg)
LS6 Total Dressed Engine Weight: (Manual only) - 497.2 lbs (226 kg)
all weights per corvetteaction.com
Fe block (iron) such as the LQ4/LQ9 block
weigh 65 pounds more than the aluminum block with the steel sleeves installed.
per a sponsor/member from zo6vette.com
personally, I am going with a LQ9 with L92/L76 and a custom cam. around the 210/218 mark, because I am going to install a blower eventually. The small cam should make more power than larger cams up to the 6000+ rpm range then the larger duration come into play with the peakiness of the curve.
personally, I like under the curve... and all the lS1 cars I have built and modified, under the curve power beats a peaky curve everytime.
Old Jan 29, 2009 | 06:27 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: just some info on weights on different engine combo's
Thats good info! Thanks for sharing.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
