my findings for the '99/'00 LQ4 fitment issues
Old Feb 26, 2009 | 08:07 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I have confirmation that the problem with the older LQ4 blocks from '99 and '00 trucks CAN be fixed so that you can use a 4L60E as well as a T56 from an LSX car.
The blocks are identical between the older and newer LQ4 blocks, it's simply the crankshaft that is different. Swapping out the crank for that of a newer LQ4, LQ9, or even an LSX car will cure the problem. I got a private message from a guy on cfmperformance.net that a good friend of his had this problem and fixed it by putting an LQ9 crank in it and now he's using a T56 behind his motor.
Here's a link to the "problem" originally encountered with this motor.
https://www.thirdgen.org/forums/ltx-...0-lq4-6-a.html
So if you've got a '99 or '00 block and you want that 4L60E or a T56, there is a solution!
Old Feb 26, 2009 | 07:14 PM
specv44's Avatar
Re: my findings for the '99/'00 LQ4 fitment issues
Yeah, we found out the hard way that the LQ4 is .44" longer than the later LQ4, 5.3's and such. Broke the pump in our 4L60E, mushroomed the converter, and took us 5 hours to get it out of the transmission.
Old Feb 26, 2009 | 10:16 PM
BlueZee28's Avatar
Yea that's a rough way to find out for sure.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Glowsock
Jan 9, 2017 04:06 PM
kah992
Aug 19, 2015 02:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
