new owner
Old Mar 1, 2009 | 01:30 PM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
new owner
Ive just pruchased a 86 camaro with a lt1 swap. it was a original 305 the motor was swaped with a 96 lt1 out of a police packaged caprice. the motor runs fine and all but it looks like it was just thrown in there. I was wondering if anyone can send me some pics or give me advice on how and where everything should be mounted. Ill send some pics of how it looks. as it sits not there are wires every and alot things just siting in there loose. So if any else has done this and give any adivce that will be great. I just want to clean up and make it look like that motor is supposed to be in there ya know.
Old Mar 1, 2009 | 03:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The proper place for this is the LTX and LSX Engine Swap subforum, where it is now.
Old Mar 6, 2009 | 03:21 PM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: new owner
ok i finally was able to go out and get some decent pics. we had a bit of a winter storm in the begining of the week. so here are some pics of the mess any help of where to put the stuff and or what it is would be great.
Old Mar 6, 2009 | 03:23 PM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: new owner
this area is my main concern
Old Mar 6, 2009 | 03:28 PM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: new owner
and what is the purpose of this?
Old Mar 6, 2009 | 03:29 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: new owner
uhh...wow what a mess
I'll see if I can get some better pics of my setup this weekend.
Old Mar 6, 2009 | 03:39 PM
Klortho's Avatar
Car: 1987 GTA
Re: new owner
Looks to me like they didn't hook the power steering up
Old Mar 6, 2009 | 11:51 PM
camaro_guy24's Avatar
Car: 91 Firebird w/ L03
Engine: LT-1 Swap still in the works
Axle/Gears: 10 bolt w/ 2.73 (Needs 3.42 w/posi)
Re: new owner
Wrong side of the engine... before it was mentioned that the motor was out of a Caprice, so I'd say that someone didn't hook up the oil cooler.
Old Mar 7, 2009 | 08:57 AM
Klortho's Avatar
Car: 1987 GTA
Re: new owner
Well, the caprice power steering line comes out on that side also, I thought the Camaro was the only one that got the oil cooler....I know that the Trans Am's didn't (at least the ones I've taken apart hasn't)
Ahh, it was a B4C Caprice, so yeah it's probably the oil cooler.
One of the things I would probably do to help with some of the cleanup is try and find an f-body harness, that way you don't have a bulkhead connector sitting almost on top of the engine, and with an f-body fuseblock, you can move that one from the blower motor and put it on the other side of the engine bay up front like in a 4th gen.
Old Mar 7, 2009 | 11:01 AM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: new owner
thats what i was thinking of doing is getting a f-body wiring harnes for the lt1 and maybe one for the 86 and just make one up and then take it all out and hook up the complete new one. im also thinking about doing a battery relocation so that i canhave a bit more room in there.
Old Mar 7, 2009 | 11:04 AM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: new owner
oh and will a 3rd gen radiator work or should i get one for a f-body w/the lt1. cause i think they used the caprice's. the one thats in there seems a lil to wide and tall. they also have the fans in the front of the radiator is that right? and the fans are always on need todo a lil trouble shooting on that one.
Old Mar 7, 2009 | 11:12 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: new owner
You can use a 3rd gen radiator.
Old Mar 7, 2009 | 11:40 AM
Klortho's Avatar
Car: 1987 GTA
Re: new owner
I'm using a 4th gen radiator and fan setup, also a 4th gen fusebox, so it was all pretty much plug and play except for the 8 or so wires I had to wire up to my dash harness.
Old Mar 7, 2009 | 02:48 PM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: new owner
well i just found out i have bigger problems than wiring. i thought the starter went out. so i took it out and got it tested and it works fine. so after i cleaned it up, i went to install it. while i was doing so i found out that the flexplate and trouqe converter were just free spinning and a lil wobbely. so just to verify i got my wife and had her to try and turn the engine over, while i was looking at the flexplate and yup the starter is just pretty much turning the flexplate and trouqe converter. kinda funny how i drove this thing for over an hour with stops back home when i purchased it and had no problems. then about 2 days if that after i got this happens.
Old Mar 8, 2009 | 02:45 PM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: new owner
any ideas what happened, or what would of caused this?
Old Mar 9, 2009 | 11:27 AM
s346k's Avatar
Car: 89 firebird/99 ws6
Engine: v888888888888s
Transmission: THtreefitty/t56
Axle/Gears: 342 all around
Re: new owner
you're thinking of 9c1, b4c only pertains to the camaro. and yes, they had oil coolers. the whole deal is removable from the block. we just swapped a 96 imp ss motor into my dad's 72 ss elcamino and removed the whole thing off the block because the header primaries were on it.
Lbibb
May 5, 2016 12:00 AM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
