4.8,5.3,6.0 Swap ?'S
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
When doing the truck motor and trans swap. What Ill need is the f-body accessories? Which one's? I know I need a f'body oil pan. And then Ill need motor and trans mounts. Im confused on the dash wiring, getting all the gauges to work with the truck harness. Other than that what else? I can get motor,trans,harnes,computer,etc...$800 so I just wanted to know what else is needed oh and I have a ss hood so I'm thinking the truck intake might work.
Car: 87 Camaro Z28
Engine: LB9
Transmission: 700-R4
Re: 4.8,5.3,6.0 Swap ?'S
Car: 92 camaro rs
Engine: lo3 305 tbi
Well I've been searching swaps for three days now and I haven't read much about the wiring and I wanted to make sure I was correct before I jumped into the swap. I've been reading both of the current 5.3 swaps.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
having the stock harness reworked for stand alone will be your best bet.
fbody accesories work well. can use fbody oil pan or ctsv pan
Car: 85 Z28
Engine: LS
Axle/Gears: 9inch/3.50 gears
Good stuff guys, I sold the lt1 and just picked up my 5.3 and any info is always helpful. what are we doing for motor mounts? Aslo, will the LS T56 bolt right up to this motor? What am I looking at for headers? These are just a few questions for now. No one better tell me to do a search.. I did.. and this thread is what I found. So lets talk 5.3's boys!!
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
The 5.3 is externally identical to the LS1/2/6, so anything that bolts to the outside of one of those will bolt to the 5.3.ALL of the questions you have so far (& probably a couple that you're still thinking of) have been answered in the sticky at the top of this forum. Read over that about 2, maybe 3 times, & if there's something that's not covered, you'll likely get a quick answer - as well as credit for a new question...
Car: 85 Z28
Engine: LS
duh... The stickies! Its easy to forget they are there sometimes. Thanks people. I'm sure they'll have all the info I need.
