weighed my ls1 iroc
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
weighed my ls1 iroc
i finally weighed my iroc
hardtop
ls1 swap
t56
stock k member
full interior
power accessories
4th gen dash including ac ventilation etc
c5 seats
but no ac yet
hardwood cowl
4th gen rear and al. drive shaft
18" replicas!
3/4 tank
weighing at 3260lbs the car by itself
hardtop
ls1 swap
t56
stock k member
full interior
power accessories
c5 seats
but no ac yet
hardwood cowl
18" replicas!
3/4 tank
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: weighed my ls1 iroc
Nice, I'd say thats a respectable weight for what you've got
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I hope to weigh mine soon to see where it ends up this season.
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Now we can use your car as a benchmark! Thanks for posting this info.
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I weighed my IROC as well at the drapstrip last summer:
LS1/T56
T-tops
stock K-member
Full interior, power everything
No A/C
No emissions
Big heavy 18" billets
LS1 brakes front/rear
aluminum DS
Full tank of gas
no spare tire/jack
no driver
3340lbs.
LS1/T56
T-tops
stock K-member
No A/C
No emissions
aluminum DS
Full tank of gas
no spare tire/jack
no driver
3340lbs.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
GREAT info guys, thanks for posting it - now I'll be able to see where my car stacks up once the swap is complete...
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
That is what I was guessing it would weigh with all your parts.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Car: 1985 IROC-Z
Car: 1984 Z28
any truck stop should have a scale. some tracks also have a scale as well.
Transmission: 4L80E/4L80E
I hope to get mine weighed at the track next month.
Berlinetta #1 weighs 3450 going down the track with empty trunk, 1/4 tank of gas and me (less when my son is driving it. . .
). Senior Member
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Sorry to crash the LS party, just another benchmark, 3/4 tank with power everything, and all the parts in sig was 3390... be nice to drop 100lbs with an aluminum LS when the LT goes boom.
I still laugh at the thought of shelby gt500 convertibles weighing in at 4000lbs.. jeez I guess you get even more than you pay for.
Car: 87 GTA
Hmmmm....I woulda guessed a little lower on the LS1 cars.
Next time I pass a truck stop (which is RARE) I'll weigh in....wait a sec....Scrap metal yard! I know where one is with a drive-on scale.
Car: RS
Axle/Gears: 9" for the ladies
I think the "magic" weight would be about 3300lbs which would include a 175lb driver and a full cage. Obviously there will be a lot of aftermarket parts, but I think it can be done.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i dont have any sfc yet. but i am runing a 4th gen tank
roughly 100lbs less with out rear seats cargo lid. and unecessary stuff in my trunk ?? .. lol
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
This gives me hope to have a 3200-3300lbs street car. I plan on a tubular front end when I get the money for it after the planned swap.
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
My '83 with 1990 383, a/c, sub frame connectors, pwr windows, 3/4 tank of gas, no driver...
3470 lbs/ on Intercomp race scales
I'm hoping for 3300-3350 with my LS1 (whenever that may be).
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
i wish i would of swapped everything over to my 86 base model (v8 5spd)
it was 3150 with the iron 305
Car: Camaro
Engine: 6.2L
Mine weighed 3520lbs with a sbc/t56 and everything else was identical to now aside from the LS1 swap. Yet to weigh it since so I would guess I'm down 150lbs or so
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
whats with 4th gen tank? is it a bolt in? probably easier too since ith has high pressure pump. think any weight savings there?
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
That seems a bit heavy for an ls1! That would mean my car weighs atleast 100lbs more than what yours all weigh... Even more cuz i have 305tpi with a 700r4...!
I thought our cars were lighter and an LS1 would have brought it down to near 3000lbs.
As you probably know, there is no such thing as a bolt-in. The lines are different than 3rd gen, the wiring is different than 3rd gen. But, the tank itself will "bolt in" right where the stock 3rd gen tank was.
Didn't seem to be much lighter, I'd guess because of the evap stuff on it. But, since the evap stuff won't be needed on the other end of the car, it's probably a net weight savings.
Also more weight on the back is better than on the front!
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
cargo lid is only a few pounds, but you may have a lot of other goodies in the back of your ride.
What do you guys think I'd be weighing in at with a tubular k member, a arms, coil overs, aluminum drive shaft, no wiper motor, no a/c, aluminum heads, no spare tire, no air pump, stock rims, man i can't remember what else i nixed. i'm actually thinking about replacing the rear window with plexiglass. Does anyone know a company that does that work?
don't do the rear window... you need it for traction, plus i heard you can't have a defogger with it anyway.
BTW how much lighter was the tubular from k-member and a-arms compared to stock and which brand did you buy? Spohn?
I also heard coil-overs weren't good for the street and only drag racing... this is just what i've heard though it might not be true...
Engine: 2002 Ls1
Transmission: t-56
could go with a notch back conversion...but yea, there are some places weight should be added and not taken away, taking away weight under the hood is good, taking it from over the back tires is bad.
heh, the rear seats weigh nothing.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
I've heard no driveability issues with the coil overs, and I've heard what you mentioned. My engine isn't done yet, so i couldn't tell you, and it's been so long since I've driven it, i won't remember how it used to drive.
Car: 1991 Camaro RS
Engine: 305 TBI
thats pretty heavy,i have a stock ttop auto 91 RS that weighs 3300 with 3/4 a tank of gas. and 3435 with me in it.
ive pulled the rearseats(not belts),spare and jack,and A/C and most of the emissions.
Engine: Cammed 6.0L LSX
I wonder how much heavier an iron 6.0 with aluminum heads would be as opposed to an LS1?
Car: 1984 Z28
80 pounds more IIRC. But the extra HP makes up for it IMO.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Car: 1984 Z28
no a T56 is heavier than a th350 with a 10" converter IMO
how heavy is an 86 stock 700r4 compared to the t56?
Car: 1985 Pontiac Trans Am
Engine: 5.7L LS1 FI
Axle/Gears: 3.23 factory 9 bolt
From LS1 tech thread:
The T56 is about 130lbs dry w/o bell. While the T5 is about 75lbs dry. that sixth gear is heavy! but well worth it IMO.
From SyTy.net:
The 700R4 is about 130lbs.
From SyTy.net:
Car: 1991 RS Camaro
Well, that's good to know. At least my transmission difference won't be very much. Wonder what a old 4 speed would weigh lol
Engine: 2002 Ls1
Transmission: t-56
well, i thought i would run by the scale today to see what my car weighs.
its an 84 trans am, with all the body kits off an 88 gta, rims etc. has ttops, subframe connects, a ford 9" with a locker, all the seats, and 3/4 tank of gas.
i was thinking it would be around 3400 since that 9" we put in was so heavy, but i guess i was wrong.. turned out to be 3140 thats without me of coarse.... and i havent even done any weight reductions yet!
i still plan...
4th gen seats
plastic ttops
and a/c removal
as well as some other small things.
i still plan...
4th gen seats
plastic ttops
and a/c removal
Engine: 2002 Ls1
Transmission: t-56
Define "bolt in".
it is lighter, i believe the 4th gen is plastic and the 3rd gen isnt.
Haven't weighed one myself, but everything that I've read on here says that the weight difference is negligible...
Car: 1989 Trans Am GTA
Transmission: M28 T56
Slipped off the pins and jack when installing it. Thankfully it only had about 18" to fall.
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
