Moroso LS1 oil pans
Old Mar 16, 2009 | 11:59 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Moroso LS1 oil pans
Check these two links out the first is the ls oil pan dimension from ls1 tech http://www.ls1tech.com/forums/conver...-oil-pans.html
The second here is the ls pans from moroso.. it looks like at least one would fit and possibly solve our k-member issues.. I priced some at Jegs and they are in the 200$ range http://www.moroso.com/catalog/catego...?catcode=17002
I don't know if these will work, just thought the info was worth sharing as possible solutions..
Old Mar 17, 2009 | 12:07 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: Moroso LS1 oil pans
DANG IT, I wish they would've been out a few months ago - I think I paid like $175 for a used one... (And not having to clearance the K-frame would've been a nice added bonus!)
Old Mar 17, 2009 | 01:11 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
This pan is $680 from summit, if you can get them for $200 I'll take several. Let me know your source.
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 17, 2009 | 06:49 AM
HDon22s's Avatar
Car: 88 iroc
Engine: lq4
Transmission: 700r4 till it dies.
x2 I thought maybe moroso released a cheaper version. Yeah right.
Old Mar 17, 2009 | 07:59 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
On top of the price...Im still not convinced that it would fit without k-member mods. It still looks like it'd be tight where it transitions into the sump. I think you need to relocate the oil filter too.
Besides...for that price tag, Ill modify the k-member haha. I wish tubular k-members were more street proven and had a slightly lower price tag. That's the best solution for a near bolt in swap.
J.
Old Mar 17, 2009 | 12:21 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I was going to look into a moroso pan but I picked up a really clean LS1 fbody pan with the windage tray and pickup for $130. I couldn't pass up that kinda deal.
Old Mar 17, 2009 | 12:27 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
im going to use a ctsv oil pan, they are pretty much identical to a fbody, but better oil control supposedly, since they were deigned for road racing
Old Mar 17, 2009 | 11:01 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
I don't think you all are looking at the right pan, if you scroll to the bottom of the Moroso catalog link you will see it, this is the one that is most promising for fit.
http://www.jegs.com/i/Moroso/710/20140/10002/-1
219.99 for the pan I even said it was from JEGs, come on folks I take pride in giving correct information, just trying to share options. To add to the price would be the 91$ pickup.. so total it together..
The pan xpndbl3 linked from summit is basically a fancy version of a stock LS1 pan, not the one I was thinking about, 20140 is the pan that is shallower in depth with more room before the sump.. From looking at everyones trouble it would seem just 1/2 an inch would solve the k-member issue. Stock is 11 1/2 inches from the back of the pan to the end of the sump.. the moroso is 9 11/16 I should think that extra inch and a bit could work wonders for some folks.
Old Mar 18, 2009 | 07:06 AM
Car: 86 Trans AM
Thats more like it... That pan looks like it might work.
However, for $310 bucks, Im still a fan of modifying the k-member. Then again, I can weld. So this pan would be a good option for someone that is looking to not modify the k-member at all or that doesnt have access to a welder.
Good info!
J.
Old Mar 18, 2009 | 10:53 AM
xpndbl3's Avatar
Car: 1984 Z28
Don't forget the extra $100+ for the lines and fittings for a remote oil filter as well.
Old Mar 18, 2009 | 09:55 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
i used the moroso steel oil pan. i had to trim the windage tray a little to clear the pickup, but it fits the k member nicely. the oil filter lines were a real pain to get on, but i've seen newer pans where the fittings are angled to get better access. i have posted a pic of my pan on here before. in the end, though, i think it cost me about the same as getting a camaro pan and pickup, but i do like the extra oil capacity.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
