GMPP plastic timing cover VS 2 piece cover
Old Mar 21, 2009 | 11:26 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
My GMPP zz383 came with a composite timing cover. It looks like crap but the rest of the engine appears to be so high quality that I'm assuming that it is good enough and that GM didn't just skimp on this one piece.
Should I be concerned?
Also, I posted up a question a while back about Comp Cams 2 piece aluminum timing covers. I didn't get a great deal of response. One member felt that they were good for dyno mule test engines but might be leaky for a street car. Any thoughts/ experience with this?
Thanks,
Jon
Old Mar 22, 2009 | 10:18 AM
Hog's Avatar
Hog
Re: GMPP plastic timing cover VS 2 piece cover
Thta composite cover is the same 1 that comes on the 1996-2002 Vortec 305/350/4.3 production engines, and the ZZ383 and HT383 and HT 383E ZZ4 crate engines.
Check on the bottom of the plastic cover to see if there is a hole for a crank position sensor. The marine engines come with the plastic cover that doesnt have this hole. You might want to install and old Vortec 4.3/305/350 crabnk position sensor or some sort of blockoff plate to keep dirt out of there.
I cant remember in the auto crate engines have the hole or not.
I wouldnt go out of my way to install a metal timing cover. Its not like you can really see the timing cover in the car anyways.
I'd love to have that ZZ383 to drop into my 97 rcsb pickup.
peace
Hog
Old Mar 22, 2009 | 08:54 PM
Car: '83 Berlinetta
Engine: 383 CI
Thanks for the reply. I wasn't so much thinking about the looks as the quality. When reading after market descriptions of their timing covers they always boast about theirs not deflecting thereby eliminating unintentional cam walk etc. Anyway, if this is going to do the job I'm happy enough to leave it alone.
J
Old Mar 22, 2009 | 09:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since factory roller engines have a retainer plate to prevent cam walk, I don't think you have to worry about cover flexing.
Old Mar 23, 2009 | 07:51 PM
Hog's Avatar
Hog
57Kid is right, with the factory setup, its a non issue. Only if you were you using an aftermarket cam button retainer could this be an issue.
peace
Hog
Old Mar 24, 2009 | 11:27 AM
Car: '83 Berlinetta
Engine: 383 CI
Excellent! Less work for me and less money too!
Thanks,
Jon
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
MY87LT
Aug 17, 2015 08:43 AM
Street Lethal
Aug 12, 2015 11:33 AM
