just wondering
Old Mar 28, 2009 | 02:20 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
just wondering
yeah I'm in the process of doin a 89 trans am GTA LSX swap..i've been goin over this in my head for about a week now..should I tear the motor down and inspect and clean everything or should I just forget about the rebuild and just stick the motor in..before you think i should take a look at these pics i took today..valvetrain is beautiful..apperantly the motor has 80,000 on it..neways thanks for any feedback..jack
Old Mar 28, 2009 | 02:56 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: just wondering
When I did my first LT1 swap the engine had 40k on it and was guaranteed to run.. with that all I did was change out the any sensors that could be crapped out or worn, cleaned it up and put it in..
If you have a warm fuzzy and don't want to mod the internals I would replace any seal that might cause you major grief later and put it in the car.
Old Mar 28, 2009 | 04:15 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: just wondering
Looks clean to me. My 5.3L i just cleaned up the outside and shoved`r in.
6.0L was stripped to the shortblock for cam heads and all new gaskets.
LS series gaskets were very well designed from the factory, and dont have any common leakin problems im aware of.
Old Mar 28, 2009 | 04:40 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: just wondering
if motor came from running vehicle then it should be no problem.
my own 5.3 has 280k miles and runs strong as new. and it tows my cars and boat, well til at least the hurrican took my boat
Old Mar 28, 2009 | 04:58 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: just wondering
Originally Posted by jackaharmon
yeah I'm in the process of doin a 89 Trans Am GTA LSX swap..
Yeah? So am I... I'm guessing that you'll be fine, like Sheldon said, the LS-series engines are pretty well designed...
92projectcamaro
Dec 8, 2015 12:25 AM
Bradsaundry
Oct 7, 2015 04:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Bigold4x4
Sep 28, 2015 05:21 PM
