LS1 Fuel Rail + Truck Coils?
Old Mar 31, 2009 | 08:09 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Well after a day of working on pulling my 305, I decided that I would try putting my truck coils on the motor, just to see how they fit. Turns out the main fuel feed line on the fuel rail exits right into the side of one of the coil packs. Has anyone else encountered this problem?
Old Apr 1, 2009 | 09:57 AM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: LS1 Fuel Rail + Truck Coils?
i just bent the fuel line up a bit carefully
Old Apr 1, 2009 | 10:44 AM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
i have those coils on my 4th gen. just had to bend the rail slightly
Old Apr 1, 2009 | 11:46 AM
andrew69_04's Avatar
Car: 92 Camaro RS
same thing i did with my s10. I will also be doing the same with my third gen. Just make sure you dont kink it.
Old Apr 1, 2009 | 03:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I remounted the coil lower on the truck coil bracket. But, the fuel rail inlet still had to be bent up a little bit to clear the truck coil bracket.
I was going to post pictures of this but didn't have enough else to say since my previous update thread. . .
Old Apr 1, 2009 | 05:46 PM
Shift06's Avatar
Awesome, sounds simple enough, I just didnt wanna go bending things for no reason.
Old Apr 1, 2009 | 06:51 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Old Apr 1, 2009 | 08:06 PM
five7kid's Avatar
Realized I hadn't taken good pictures of this, so went out and took a couple. You can see how the #5 coil is relocated. And, the fuel rail fitting originally was horizontal.
In hind sight, truck coils on the passenger side and LS1 coils on the driver's side would make more sense. But, I didn't think about that until after I had made the deal for the full truck-for-LS1-coils trade, and I suppose there are "form" guys would would consider that anathema.
Of course, the guy in the latest Super Chevy mag who put an LS in his 1st gen moved the coils under the dash. . .
Attached Thumbnails LS1 Fuel Rail + Truck Coils?-5-coil-relocation.jpg   LS1 Fuel Rail + Truck Coils?-fuel-rail-fitting-new
Old Apr 1, 2009 | 09:02 PM
Car: 92 Camaro RS
ok im jealous now. You hve a motor sitting in your car, mines still on the stand
Old Apr 1, 2009 | 09:58 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Old Apr 1, 2009 | 11:40 PM
five7kid's Avatar
The 305 has been out for 13 months. I've had the LS1/T56 for 19 months.
Are you still jealous?
Originally Posted by SheldonZ28
Yeah, yeah. I'm a function-over-form guy all the way. I take covers like that off engines, not add them.
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bryan F
Aug 18, 2015 02:28 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
