Fuel pump wire on 91 Z
Old Mar 31, 2009 | 08:38 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Where is the fuel pump wire to the tank on a 91 Z. I completely eliminated the stock engine harness with the factory fuel pump relay on it and I just need to find the wire to the tank. I believe the relay was mounted on the driveside firewall but I dont think the wire went to the drivers side bulkhead, Im thinking it went to one of the connectors under the dash near where the pcm was. Can anyone verify that? Im pretty sure its a grey wire.
Old Mar 31, 2009 | 09:12 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuel pump wire on 91 Z
C100 pin G4 is power to the fuel pump
Connect your new relay output to this
Yes it is gray factory
The PCM controls relay engauge which is Dk Grn/Wht
LS1 PCM pin Red 9 is connected to this
Old Mar 31, 2009 | 09:49 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Cant beleive I missed that, thanks alot for the help.
Old Apr 5, 2009 | 10:48 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Do you know which wire would be the volt gauge on c100, Is it Brown, pin G8?
Old Apr 6, 2009 | 04:07 PM
Pocket's Avatar
Car: 91 Trans Am
Correct, Im not sure why the coolant relay is also ran thru there as it goes directly to the gauge
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
