oil gauge lt1?
Old Apr 2, 2009 | 03:25 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
oil gauge lt1?
I've got the gauge connected right. Tan wire from bulkhead connector to the solid tan wire in the lt1 harness. When you start the car the gauge just goes to 60 and stays there. Turn it off and it goes back to 0. I unplugged the oil pressure switch last night and the gauge still would sit at 60 with the car running. I believe it has to be a bad ground now. Where would I start looking for a short in the ground?
Old Apr 4, 2009 | 10:59 PM
rdog30's Avatar
Car: 85&95 Trans am
Re: oil gauge lt1?
anyone?
Old Apr 5, 2009 | 12:03 AM
muddyjimmy's Avatar
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
Re: oil gauge lt1?
When the key is in the run position but the engine is off does the gauge still read 60 psi? Have you checked the actual pressure with a manual gauge? I am not sure if there is a difference in the 4th gen and 3rd gen sending units but I am running a 3rd gen sending unit and mine reads correctly. You may just need to swap senders.
Old Apr 5, 2009 | 03:55 PM
rdog30's Avatar
Car: 85&95 Trans am
Re: oil gauge lt1?
With the key in run the gauge reads 0. Have not hooked the mech. gauge up yet. With the engine running the gauge is maxed out. When you unplug the connector from the pressure switch the gauge is still maxed out.
Old Apr 5, 2009 | 05:19 PM
muddyjimmy's Avatar
Re: oil gauge lt1?
When you unhook that wire it should max the gauge. When you jumper that wire to ground it should read 0 psi. With the key in the run position the sender has very low resistance. I would check the actual oil pressure and and make sure you have the correct sender for the cars gauge. It does not sound like there is a wiring issue though.
Old Apr 6, 2009 | 11:44 PM
rdog30's Avatar
Car: 85&95 Trans am
Re: oil gauge lt1?
After checking the part numbers the guy at the parts store gave me the wrong sending unit. I got the one for the light instead of gauge. That should fix my problem when I get the right sending unit.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
