Some LT1 questions
Old Apr 6, 2009 | 09:24 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Some LT1 questions
alright i don't know much about LT1s but,
are the LT1 blocks the same as any other 350 block?
and if they are the same, presumably i could build an LT1 out of any 350 block?
and last, is it possible to have a carbed LT1?
Old Apr 6, 2009 | 12:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No. Reverse cooling, cam-driven water pump - very different. The crank is the same as one-piece RMS 350, rods and pistons will interchange, cams can be used (LTx requires a long cam sprocket pin), but that's about it.
Since they aren't the same, no. But, the Vortec heads are very similar with regard to chamber shape and port flow.
Yes, but in my personal opinion, might as well build a Gen I SBC with Vortec heads.
Old Apr 6, 2009 | 02:23 PM
Convoy25's Avatar
Re: Some LT1 questions
i pretty much settled on a 383, i was just curious and looking at other possibilities of engines
Old Apr 6, 2009 | 04:52 PM
five7kid's Avatar
There are many 383 LT1's out there. A very potent combination. But, it doesn't make sense unless you're starting with an LT1.
A 383 with Vortec-style heads would be a good runner.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
