Will an LT1 timing cover boolt stright on a L98 TPI motor?
Old Apr 20, 2009 | 05:53 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Wanting to change to sequential injection on my 350m tpi, bought an aftermarket fuel/ignition ecu, but need to run a cam sensor to do it....
so can i just bolt on the l1 timing cover with the cam sensor or do i need to do heavy modding, or is there an easier way?
Old Apr 20, 2009 | 08:17 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Will an LT1 timing cover boolt stright on a L98 TPI motor?
No, the cover is different between an L98 and LT1
Old Apr 20, 2009 | 09:59 PM
evilstuie's Avatar
ok then....
So how do i install a cam sensor on a TPI motor?
Old Apr 20, 2009 | 10:33 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
The L98 (traditional SBC) doesn't use a cam sensor. Not sure on how you would make that work.
Old Apr 20, 2009 | 11:13 PM
Pocket's Avatar
Car: 91 Trans Am
Vortec truck distributors use a single tooth sensor and being driven off the cam it gives accurate cam locations. Since the cam sensor is only used to determine cycle, this should work
Old Apr 21, 2009 | 06:21 AM
Klortho's Avatar
Car: 1987 GTA
And actaully now that I think about it, the LT1 doesn't have a cam sensor either, the 96-97 has a crank sensor.
I would look in the ECM section and see what guys are doing, I remember something about using a van PCM and some have gotten the LS1 PCM to work with the TPI.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
squiggy2
Aug 9, 2015 09:30 PM
