FAN WIRING QUESTION
Old Apr 23, 2009 | 03:27 AM
88LT1Drop's Avatar
Car: 1988 Camaro Conv.
Engine: 96 LT1
Axle/Gears: 3:73's
FAN WIRING QUESTION
Hey guys just wanted to know if the dark green and dark blue wires are suposed to send a 12v signal to my fan relays? i ask because jegs.com has a fan relay kit that has 4 wires. a ground. ign, to fan, and bat. and was wondering if i hooked up the ign. wires on the kit to my fan wires, would it work?
Old Apr 23, 2009 | 06:12 AM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
Re: FAN WIRING QUESTION
If i remember correct, the green and blue wires are actually the grounds to the relays and the computer turns the fans on by grounding out those wires then.
Old Apr 23, 2009 | 09:01 AM
andrew69_04's Avatar
Car: 92 Camaro RS
This is correct. The ECM controls all the grounds in the system. the green abd blue wires are your grounds for high and low speed fan relays.
Old Apr 23, 2009 | 09:16 PM
88LT1Drop's Avatar
Engine: 96 LT1
Axle/Gears: 3:73's
okay. good thing i asked then i thot they would connect to the ign. on this kit. so if i hook up the blue and green to the relay grounds it should work?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
