LS1 Motor Mounts
Old Apr 29, 2009 | 08:50 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
LS1 Motor Mounts
I read somewhere on this site that the transdapt 4572 plates would allow us to use the factory mounts to swap the ls1 in. Well we are WAY off. What do we need to get to make it work?
Old Apr 29, 2009 | 09:22 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: LS1 Motor Mounts
Here's what i found when i put them in mine:
https://www.thirdgen.org/forums/ltx-...questions.html
No go, scrapped the mounts, bought LS1 clamshells, and fabricated horseshoe brackets
Old Apr 29, 2009 | 09:59 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Does that mean the mounts you traded me are no good? :'(
Old Apr 30, 2009 | 06:31 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
It Depends. Like i posted in there, there was interference with the k-member.
Theres 2 ways of fixing this.
1. Move the thirdgen clamshells back on the k-member 1".
2. Extend your driveshaft 1" and notch the K.
Look at "Maxxmitchell"'s swap thread on LS1tech. He used them, and notched his K.
Try to mount them, let me know what your situation comes out as, if you cant see a way of getting them to fit, ill fabricate some horseshoe brackets for you
Old Apr 30, 2009 | 01:02 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
i used the spohn and 02 clamshells, worked fine.
never used the td, they just dont look right to me for 3rd gen swap.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
