LT1 coolant lines
Old May 7, 2009 | 11:13 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
LT1 coolant lines
I tried doing a search and couldn't find the answer, I need to know how to run the cooler lines. The water pump has three smaller outlets, i'm not using the heater, can I just cap them? Or do I have to loop them together. Which one goes to the radiator?
Old May 7, 2009 | 11:27 PM
Firebat's Avatar
Re: LT1 coolant lines
I think you can cap off all 3, and if you have the LT1 radiator, you can cap the small lower opening.
Read this: http://www.ls1tech.com/forums/lt1-lt...ater-pump.html
Might not be much info in that link on the info you want. You can cap the lines and hose clamp them down. Lower one would go to the LT1 radiator.
Old May 14, 2009 | 02:32 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
The B-body water pump I got off of a Caprice only has two smaller outlets.
Old May 18, 2009 | 12:52 PM
Engine: 5.8
It is overheating I am using a thridgen radiator and had all the lines caped then I ran the one from the lower driver side of the pump to the radiator and still over heating. thanks
Old May 19, 2009 | 10:19 AM
Firebat's Avatar
The hard line from the heads should not be capped. Its a hard line that runs along the intake manifold. That line goes to the radiator somehow.
If thats not it, test the thermostat. Take it out, throw it in a kettle or sausepan with water, then put that kettle on a kitchen stove. Heat it up to about 200 degrees or boiling water point, if it changes(opens/closes) then its good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
New2Chevy
Sep 28, 2015 12:35 AM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
L0tuS
Sep 4, 2015 11:16 PM
