Custom ac bracket when using adapter plates
Old May 11, 2009 | 07:24 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
This setup will allow you to have ac in the original location when using relocation adapter plates. These are the plates that go from the original clamshells to the ls1.
This won't make you have to notch the k-member. You have to use a sanden compressor(6 rib). It will line up with the main accessory belt.
This is designed for the vette accessories. If you use it for f-body add .75", and for truck add 1.5".
Hope this helps someone out.
These are all on 8.5x11 paper.
morrow
Jan 13, 2024 12:29 PM
TheTraut88
Sep 11, 2015 05:16 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
