93 zz28 lt1 into 92 RS 305 tbi f body
Old May 21, 2009 | 07:06 PM
cammaster2001's Avatar
Here is the problem, i have been reading about VATS system for about two weeks now, and trying to figure out how to get this car started. i have the lt1 engine, pcm(ecm) and wiring harness for the motor. i have tied the two wiring harnesses into each other and have power to the gauges, check engine light, ect ect. when i turn the car on, the fuel pump comes on by ignition, not toggle switch, but the engine will not crank. i read the vats system shuts off the fuel pump and the starter, but the fuel pump works and i have not touched the vats module. i have checked the park/ neutral switch and its wired in correctly. i even tried jumping the starter over with a screwdriver, it turned over, but acted like it had no spark. Any help is greatly appreciated. thanks.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
