Fuel pump question again
Old May 24, 2009 | 08:16 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Hey guys. I know Ive been pretty quiet for the past forever but thats mainly due to being over 8000km away from my beloved Camaro over the past 9 months.
Last August my car decided to kill another fuel pump. This time it was a Walbro 255lph. I need to replace it.
I am aware that Walbro fuel pump manufacturing was bought by some company TI and everyone is having issues. They usually last a couple of months. Mine didnt last a season.
I am trying to do things on a budget and I dont like doing things over again so if you guys could suggest something to replace my dead Walbro it would be greatly appreciated. Maybe post up price range as well.
I am also in Canada so that makes things slightly more complicated than if I were in the US. Keep that in mind.
Cheers!
Kubus
(my fuel pump wiring is getting done very soon as well so it will be all proper and new)
Old May 24, 2009 | 10:31 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Re: Fuel pump question again
Have you tried Racetronix??? You can get their pump and their upgraded wiring harness and finish it properly all at once.
The pump is a modified walbro 255 but Racetronix will stand behind what they sell.
http://www.racetronix.com/RX-F99-FPKG-2.html
Old May 24, 2009 | 10:33 AM
Car: 1991 Camaro RS
I havent looked at Racetronix but I have heard good things. If the Walbro has died and its a common thing... Will the Racetronix not die too?
Old May 24, 2009 | 03:17 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Racetronix pumps seem to be working well, ive installed 3 of them in the past few months, all are working like a charm.
Oh, and Racetronix is located in Markham, ON. So that makes shipping a tad easier
Old May 25, 2009 | 12:33 AM
Car: 1991 Camaro RS
Which one of their pumps would I get? The TPI/TBI one? Or one of the other ones?
Old May 25, 2009 | 08:26 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I got the 255 lph pump for TPI cars...
Old May 25, 2009 | 05:50 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
As rumble said, 255lph TPI setup.
Jack @ Racetronix is a good guy, i helped him make his 00-04 Vette Hotwire manual (I work for Champion Motors)
If you want to get the pump, call rob @ champion Motors, we've got a ton of racetronix stuff in stock. He can hook you up.
Old May 25, 2009 | 06:10 PM
Car: 1991 Camaro RS
Contact info? Im still in Europe so I need to pass it on to a buddy of mine who is looking after my car.
Old May 28, 2009 | 02:40 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Kubus-
We have been missing those great pics of your car!
I was thinking some on the fuel pump problems you and others have had.
I have not put my LS1 in yet. I still have an Accel fuel pump on my 383 Super Ram set up. I also did short track in a motorcycle engined car (Bosch pump).
My experience and observation has been that most pumps don't break, as long as they are set up with a free flowing return. WHEN the returns back up, or (worse) are left out, the pumps overheat and break. One guy I know (who drove fast and built even faster cars), looked at the 2002 ZX-12 that had the return in the gas tank. He saw just one fuel line and concluded no return was needed. The car went through several fuel pumps (and DNFs) until someone figured out what was going on.
SO, is the return as generous as the feed? Make sure your pump is not being blocked.
Also, does it have a free flowing feed? Filters want to be upstream. you can have a screen type filter, but no more. Pumps push, the do not like to suck. I think the watch word is do not mount the pump noticeably higher than the fuel source (tank). Lastly, make sure to keep all your filters clean. If you hear your fuel pump laboring, fix the problem. It should just buzz along.
Hope this ramble helps.
Old May 28, 2009 | 07:17 PM
Car: 1991 Camaro RS
Originally Posted by Flip 2
Kubus-
Thanks for the compliment. I forwarded it to my buddy. Maybe that will help him out.
Old Jun 9, 2009 | 03:23 PM
Car: 1991 Camaro RS
I think the guys back home may have solved the issue. When my alternator died in Michigan, the guy replacing it stole my 4 gauge wire and put in a 10 gauge. Thing melted it. FML
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
