engine finally running but????
Old Jul 11, 2009 | 02:02 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
ok so I finally got my LSX swap running, but like most of everybody problems on here, it shuts off after like three seconds..meaning theres a problem in the vats department..so this is how I have everything setup, i got a full pullout from a 98 camaro..I got the entire wiring harness for the car, including the body control module..so what I decided to do was get a key it the same resistance as the new LSX..so i found the wires comming out of the ignition switch and wired them to the new bcm..so this setup should work right??just wondering if anyone else has done the swap like me with success..any help would be greatly appreciated..thanks
Old Jul 12, 2009 | 08:27 PM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
Re: engine finally running but????
are you trying to keep vats because you want? If not, since its an fbody harness you can build or buy a vats bypass box that you wire into the harness that acts like the bcm sending the "everything is ok to start" signal to the computer. Also if you have tuning software or are planning to get tuned, it can be disabled at the bios level so that its never an issue again.
Old Jul 12, 2009 | 10:21 PM
yeah actually i really am tryin to keep vats...i live in south fl..yeah I know theres the vats bypass box and I could always just tune it out, but i wanted to go the cheapest route..neways thanks
Old Jul 13, 2009 | 03:53 AM
007BALT's Avatar
Car: 91 Red Z28 G92 Spohn Suspn
Engine: 6.0/L92 Supercharged. Fully Built.
Transmission: 6L90E + G8 Shifter
Axle/Gears: 3.08
General Rule of thumb, when doing a swap, and you want it to run like factory, its not going to be cheap.
Old Jul 13, 2009 | 07:50 AM
andrew69_04's Avatar
Car: 92 Camaro RS
if your using the full harness and bcm out of the 98 car, all you need is a key with the correct resistance to match the key from the 98 car and you will be fine.
Caspar
Jun 19, 2016 11:19 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
