LS1 block questions
Old Jul 19, 2009 | 06:01 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
LS1 block questions
is there any difference between a 98 LS1 block and a 2003 LS1 block..also will the heads inner change between the two.. my 98 block a blown, so I was just going to change everything over to the 2003 block, if everything fits..hopefully it does..
Old Jul 19, 2009 | 06:03 PM
Re: LS1 block questions
one more quick question..I know that I'll have to get new head bolts but what about the mains...are they also torque to yeild bolts as well..
Old Jul 19, 2009 | 06:12 PM
one92rs's Avatar
Car: SOLD!!!!!
what are you gettin the ls1 out of for a 2003. i know that a camaro and trans am were snubbed after 2002. it could be coming out of a vette or a gto.
according to my tattle tale book-
rear cover oil passage better-bulkhead vent windows-was converted to all short head bolts-cam bearing pearent bores to 50mm instead of 25mm. this is for the 2003
heads should bolt on. the thing about all ls1 bolts. i like to explain them as an m&m. they are hard on the outside and soft in the center. if you want to do it right. replace all bolts from heads and mains. arp would be a really good investment right about now. i have reused rocker arm dolts and outer engine bolts. but never the head and mains.
Old Jul 19, 2009 | 06:24 PM
yeah the block is comming out of a vette..but everything should mount up right...there shouldn't be any big differences right??
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
reiderz iroc
Aug 13, 2015 04:57 PM
