F-body vs. vette LT1
Old Aug 23, 2009 | 05:55 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I have a 1994 camaro LT1 and want to run corvette LT1 bracket for the alternator so I can run the Corvette LT1 procharger kit.
I have an ATI damper for a 1994 camaro. Can this be used with a corvette setup or do I need to get a damper specifically for a corvette LT1? Im not sure if there is an alignment difference for the belt.
I am not running PS or A/C.
Old Aug 25, 2009 | 08:59 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: F-body vs. vette LT1
you need to get one for the corvette. the vette drive belt is about an inch further away from the engine.
Old Aug 25, 2009 | 10:11 PM
Car: 1992 z28
Is this the only thing that is really that different? How about radiator and hoses... is that different between the two?
Old Aug 25, 2009 | 10:22 PM
BCdawg57's Avatar
the fbody wp is different than the vette one. but the wp is not belt driven so that irrelevant to your original question. All you have to do to use vette accessories with the fbody engine is to get a corvette crank pulley.
Old Aug 25, 2009 | 10:41 PM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
Do you have this bracket yet? If not, let me know, I have a complete set of LT1 vette accessories in the garage I'm trying to get out of here.
Old Aug 26, 2009 | 08:33 AM
Car: 1992 z28
Ok, I will probably jsut try to get a hold of an entire corvette crank, hub setup and then now I need to try and return or swap my F-body ATI damper with a Corvette one.
Jay87z - I am going to get an alternator bracket from March because I do not need that whole corvette bracket. Takes up too much space and is heavy. I am keepign things very minimal and will just ahve an alt. bracket
gixxer92
Apr 12, 2022 12:09 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BDR
Nov 7, 2015 03:05 PM
