Neutral Safety Switch and you!
Old Aug 29, 2009 | 05:20 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
My 6.0 swap won't start.
Seem to be getting fuel. (wet plugs)
No spark.
I have power to coils and control power for packs.
Hptuners, says CKP P0335, but I put a new one in it and no change.
triple checked the wiring and plug, it "rings" out just fine and it has 12.7v at the right pin, with key on.
Have a 2002 6.0l/4l80e "411" computer and Hptuners mods just to get it started... emissions off, and vats (fuel pumps work)
tired and couldn't think anymore, so I went home and took a shower. and looked at some pin out diagrams.
I don't remember using P 34 Neutral safety switch, it is still hooked up to the car but not the PCM! is that maybe it?
if not what else may it be?
Old Aug 29, 2009 | 08:12 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Neutral Safety Switch and you!
B32 and B34 are the PN pins that must be grounded to run
Some pinouts call for one or the other, some call for both. I err on the side of caution and ground them both as more grounds than necessary changes nothing. Too few... well you know
Old Aug 29, 2009 | 11:51 AM
fun Pain's Avatar
Transmission: 4l80e
sweet, working by yourself on lil problems like this takes a toll. Taking a break really helped, and so did you I will give that a whack...
still if anyone knows something else that it "could" be let me know...thanks
Old Sep 1, 2009 | 10:18 AM
fun Pain's Avatar
Transmission: 4l80e
On this truck, "411" pcm 2002 diag. for a 4l80e it also calls for c1(blue)72, c2(red)62 to be grounded by the Park/ Neutral Safety Switch .
didn't fix the crank, but no start problem!!!
https://www.thirdgen.org/forums/ltx-...ird-6-0-a.html
(added for searchers)
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
