tach not working on new engine
Old Sep 2, 2009 | 09:24 PM
92tracker's Avatar
Car: 92 firebird formula
Engine: 2002 LS1/6 350 rwhp
Transmission: 4L60e
Axle/Gears: 342
The engine is an o2 LS1 installed into my 92 and the tach will not registor any reading. I connected up the white wire to the new harness and nothing any help on this would be greatly appreciated
Old Sep 2, 2009 | 09:26 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: tach not working on new engine
More than likely the tach needs the bump-up resistor mod. It fixed mine Search on ls1tech for it.
Basically what you need is a 680 ohm resistor wired up to A) ignition switched power and B) the white wire.
Have fun!
Old Sep 2, 2009 | 09:36 PM
92tracker's Avatar
Transmission: 4L60e
Axle/Gears: 342
Thanks I will give that a try!
I had my car out today for the first time what a difference the new engine makes
Old Sep 2, 2009 | 10:40 PM
andrew69_04's Avatar
Car: 92 Camaro RS
i didnt have to do anything with my tach to make it work. seems to be functioning properly (my cars a 92). only problem i've encountered is it reads the wrong rpm due to the tach signal
Old Sep 3, 2009 | 08:02 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Try switching the tach to 4-cyl. mode, & see if it gives the correct reading.
Old Sep 4, 2009 | 05:59 PM
Car: 1987 GTA
Transmission: 4L60e
In efilive, my tuner used a 3 for this value. Dead on.
Old Sep 4, 2009 | 08:54 PM
Car: 92 Camaro RS
From what i have found from reading, a value of 4 is supposed to change the frequency to match the v6 tach. i might try both values and see which works best.
Old Sep 4, 2009 | 09:01 PM
V8Rumble's Avatar
THAT is weird. I've seen several instances on LS1Tech where people have toggled their tachs over to 4-cyl mode, & it's worked - but I've never seen ANY reference to a 3...
(Maybe you got one of the ultra-rare "Geo Metro" LS1 variants...???)
Old Sep 4, 2009 | 09:44 PM
Car: 92 Camaro RS
Were not talking about a 3 cylinder mode. The ls1 tach runs off a 4 cylinder frequency (#6 value in the pcm). in order to run the ls1 motor on a 6 cyl tach you have to change the tach frequency so the tach will read the correct rpm. from what i have read on tuning forums, you have to change the value in the pcm to a 4 to run on a 6 cyl frequency. make sense?
Vintageracer
Jan 10, 2020 05:33 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
