first engine swap- LT1/T56
Old Mar 7, 2010 | 09:40 PM
  #301
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Re: first engine swap- LT1/T56
i dont know what im going to do about my leaking brake line now... Summit found a pair of rear drum brake lines for 40 bucks, does that sound right? theres no image for them so i would have to go on faith.
http://www.summitracing.com/parts/RSD-FRA8401S/
tomorrow ill roll the car outside to finish draining the tank, and hopefully primer the engine bay
~Steven
Old Mar 7, 2010 | 09:51 PM
  #302
thenjoshsays's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: 4th Gen/3.23/Posi
See the ship date on that thing? I mean it may not make a huge difference because the likelihood of being all done by then may not be too great, but you could always just go up to Advance Auto and grab some of their lines with the proper ends... buy a cheap bender... and bend to fit.
Old Mar 7, 2010 | 10:08 PM
  #303
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
This.
Some line close to the right length is a couple bucks. You can bend it by hand. All you really need is a flaring tool, so if you have to cut the line, just reflare the end, and down the road you go.
Old Mar 7, 2010 | 10:09 PM
  #304
kthxbai's Avatar
Car: 1985 Z28
ok makes sense. i think i have a flaring tool around somewhere... how exactly does a new piece mate to the old piece after being flared? then again the lines are pretty rusty and it might be nice to have new stainless ones from front to rear. Ill think it over.
looks like i need that fuel filter to make the fittings ive got work unless someone has a thirdgen filter they dont need.
~Steven
Old Mar 7, 2010 | 10:29 PM
  #305
Car: 92 RS
Engine: 305 TBI
just be careful if you choose to bend by hand - if you bend too far, it'll kink. I prefer to use a bender - they're really cheap for a cheapo one that'll get the job done (less than the cost of another line if you accidentally kink it...) and it'll look more professional having an accurately-bent piece rather than a hand bend. Will both work? Sure. Just a matter of how clean you want it to be.
Old Mar 7, 2010 | 10:59 PM
  #306
Pocket's Avatar
Car: 91 Trans Am
You can buy AN filters, they are significantly more expensive than the stock $7 units
The piece in your link is essentially a very fine stock replacement
Go with the stocker, the saginaw to AN adapters in the diagram are there to mate to the stock style filter. If you get an AN filter, then disregard the adapters and hook the hose end directly to it
Old Mar 7, 2010 | 11:01 PM
  #307
Pocket's Avatar
Car: 91 Trans Am
Practice with the hardline flaring tool a few times before you do the finished line for the car. Its not something you can just wing it and get by with. Also, be sure to get a GOOD flaring tool. It will make the difference
Old Mar 8, 2010 | 05:25 PM
  #308
kthxbai's Avatar
Car: 1985 Z28
ok i ordered that fuel filter and decided to also order new stainless lines for the both rear drums. where is the best place to mount the filter when i start making my lines hopefully this friday?
~Steven
Old Mar 8, 2010 | 06:48 PM
  #309
Pocket's Avatar
Car: 91 Trans Am
Under the drivers rear seat. This keeps it higher than the frame so road debris will never have a chance to rip it off while driving and is well clear of moving parts
Old Mar 8, 2010 | 09:37 PM
  #310
kthxbai's Avatar
Car: 1985 Z28
guess ill have to make a bracket to hold it up there. i also dont want it perpendicular to the lines like that, ill have to find a good spot.
i was going to finish my wiring harness tonight but i just dont feel confident with where to put my fuse block / how long the wires need to be to put it some place good, either by the c100 or on the pass side behind the heater box. When i was looking through the only thing i noticed was that I have a wire labeled Alternator out of my C100, brown, that Pocket mentioned running to the Fans fuse at some point? I have my fans/alt fuse taking power from ign and giving power to the fans relay and the single alt wire w/ resistor. Where does the c100 wire go?
~Steven
Old Mar 8, 2010 | 10:02 PM
  #311
Pocket's Avatar
Car: 91 Trans Am
If you've got the fans/alt covered, then tape off and hide the C100 wire, you wont use it anymore
Old Mar 8, 2010 | 10:53 PM
  #312
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by kthxbai
i also dont want it perpendicular to the lines like that...
That's the stock location for EFI 3rd gens.
Old Mar 9, 2010 | 08:29 AM
  #313
kthxbai's Avatar
Car: 1985 Z28
my reason was just because i dont have those 90 degree fittings. Would there be room to put it streamline so i dont have to get new fittings or try to force the braided lines over?
Old Mar 9, 2010 | 08:52 AM
  #314
Pocket's Avatar
Car: 91 Trans Am
There really isnt a good place other than right there. Behind that is the axle and gastank. Infront is the trans tunnel which is filled with moving and exhaust parts
The only other option is the engine bay
You could get away with only two 90*s right there with the 3rd gen style filter. Your return line should flex enough to clear stuff
Old Mar 9, 2010 | 09:50 AM
  #315
goes12s's Avatar
its looking good
Old Mar 9, 2010 | 09:52 AM
  #316
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Here is a picture of what the stock fuel lines look like. I snapped a shot when i removed mine to replace them with -8an ss braided lines
Old Mar 9, 2010 | 04:18 PM
  #317
kthxbai's Avatar
Car: 1985 Z28
grr. i ordered the filter to avoid needing different fittings and now i need more fittings anyways?
is the space really tight enough that you cant just rotate the filter 90*? looks to me like you could mount it a touch more inwards and parallel to the lines and use the flex in the lines to get over into the tunnel to run them forwards?
tomorrow its supposed to be 65 outside so im going to try to prime up the engine bay and drain my gas tank. After that i can move forward on the fuel tank and consequently the lines...
i also started pulling the front steering for my rebuild kit. My teacher mentioned a pitman puller to get the centerlink off of the stud?
Old Mar 9, 2010 | 05:21 PM
  #318
five7kid's Avatar
Not really. Here's a shot from a different angle.
Old Mar 9, 2010 | 09:49 PM
  #319
kthxbai's Avatar
Car: 1985 Z28
ok i see now. Im going to at least give it a shot at a slight angle and see how much i can bend the lines without the 90* pieces. Hopefully it will work out. If not ill pony up and buy them.
i made a list of all the stuff i need to do tonight, and it scared me horribly. Ive been really frustrated with how little time ive had recently to get things done, so im going to try to kick it up a notch in the coming weeks. Thanks as always for putting up with me.
~Steven
Old Mar 10, 2010 | 09:31 AM
  #320
hey idk what kind of lines you are using for the feed but to make you feel better i ran -8an from the tank to the front, and im using an inline fuel filter that is about 2 inches longer than stock and was able to put everything in the factory fuel filter space without any 90* or 45* its all straight fittings but again im using stainless steel braided line which is a bit flexible, and the filter is also not perpendicular to the lines but diagonal. Ground clearance is just like stock.
something like this,
ill try to snap a shot when i get home
Old Mar 10, 2010 | 09:32 PM
  #321
kthxbai's Avatar
Car: 1985 Z28
yeah i have 6AN braided SS, thats exactly what i was thinking. the filter showed up today and its pretty small, so it should work. I need to make a mount for it somehow....
today i installed all of my spohn steering rebuild except the ball joints:
heres the old stuff- which was an absolute pain to get out. I had to use a gear puller rigged on top of a pickle fork to get the pitman arem to let go of the centerlink. A few other studs were stuck, and it wound up taking my whole hour of work time today. I greased up my new components, and hand tightened everything with the wheels straight. I wanted to get the car outside today, but i need steering to do that safely...
the bad news is one of my tires fell over and cracked my center console into four pieces
Old Mar 12, 2010 | 04:56 PM
  #322
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
that sucks..check out ebay or on here you'll find something..im baout to do my ball joints too i just finished my front end
Old Mar 12, 2010 | 05:11 PM
  #323
Pocket's Avatar
Car: 91 Trans Am
Hopefully your balljoint will separate easier than mine did. The castle nut backs off maybe half a turn before the shaft froze to it and spun inside the housing. I had to cut it off. Do you know how long it takes to cut hardened steel the size of your thumb with a hacksaw?
A long time
Old Mar 12, 2010 | 06:19 PM
  #324
five7kid's Avatar
That's why God gave us nut splitters.
Old Mar 12, 2010 | 06:24 PM
  #325
Pocket's Avatar
Car: 91 Trans Am
Is this an actual tool or a joke about women?
Old Mar 12, 2010 | 06:33 PM
  #326
five7kid's Avatar
When have you ever heard me joke about women?
http://www.harborfreight.com/cpi/cta...emnumber=66419
Old Mar 12, 2010 | 07:03 PM
  #327
kthxbai's Avatar
Car: 1985 Z28
thanks for the ideas, i couldnt get anything over the 7/8" nut, and i dont have an open ended wrench that big so im going to put off the ball joints since i can do them whenever relative to the swap.
today i used some old radiator hose as a wrapper for my fuel filter and bent two metal straps to make a mount that i can bolt in however i see fit.
basically glorified hose clamps, but strong enough and galvanized steel.
i also dug up my carpet enough to find my fuel tank connector, which is three wires. One of them is snipped under the car before the connector but they are all intact on the interior side... wierd. I dont want to take out alot of carpet and stuff to run new wires, so i was thinking about how else i could do it. Not alot came to mind though, any suggestions or is everything coming out?
~Steven
Old Mar 12, 2010 | 07:40 PM
  #328
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
you could just run the new ones along side under the kick panels..if you dont wanna do that then pull the carpet.
Old Mar 15, 2010 | 05:33 PM
  #329
kthxbai's Avatar
Car: 1985 Z28
alright so i found my three wires up by the pedals where they pop out from the carpet, and I decided I am just going to repair them under the car and stick with em. Since I already had most of the carpet up back there though I ran all of my audio wires up the center console along the side of the hump to clear where the shifter will be and up to the head unit. That was all i could do with the rain outside and it being Monday.
In other news I got into Georgia Tech and won an NROTC scholarship! Go Jackets. I also got into Virginia Tech's University Honors so Im going to have to pick one soon. I am going down to Georgia tomorrow night and will be away till thursday. So friday i am planning to leave the car outside and i will go in and finish this painting business once and for all over the weekend.
~Steven
Old Mar 20, 2010 | 05:02 PM
  #330
kthxbai's Avatar
Car: 1985 Z28
i got alot done today. i rolled the car outside for the weekend yesterday, and my dad and I went in early and got in a good day of work. First off I cut the hole for the fourth gen coolant res:
then i drained and removed the old fuel lines. We did a final cleaning and primed the bay:
max pics.
Old Mar 20, 2010 | 05:07 PM
  #331
kthxbai's Avatar
Car: 1985 Z28
since its saturday the school was empty so we had the whole parking lot in the back. it was beautiful outside too, in the seventies. I have the sunburn to prove it now haha
did the first coat of black.
the biggie for the day was dropping the fuel tank and installing my new sender and pump. it wasnt actually too bad once we figured out what was going on down there. here is what we did- first i had removed all the shielding and the rear track bar and brace. we then jacked up the diff, unbolted the shocks, dropped it down, removed the springs. then we unstrapped the tank and wrestled for a while since that is all the haynes manual had in terms of rear end work. we got nowhere for about half an hour, we we went ahead and unbolted the junction in the brake line to give it some more flexibility, and unbolted the brackets on both sides that the swaybar end links connect to. the end links were threatening to snap so we just took the whole thing off. it worked perfectly. at that point we got the rear end almost all the way to the ground without over stretchign anything and the tank fell right out. drained it a bit more, but left some gas in to keep it from rusting. i put in the new sender, plugged it in, and put everything back together.
heres the final pic of the paint work.
~Steven
Old Mar 20, 2010 | 11:13 PM
  #332
Car: 92 RS
Engine: 305 TBI
Lookin good! This weather really has been amazing. Good to see some nice progress there. And congrats on the scholarship! Is that a full scholarship or partial??
Old Mar 21, 2010 | 11:09 AM
  #333
kthxbai's Avatar
Car: 1985 Z28
its a full four year scholarship. which means they pay for my tuition, books, and i get a monthly stipend while in school.
~Steven
Old Mar 21, 2010 | 07:40 PM
  #334
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
sickk! whens the motor going in??
Old Mar 21, 2010 | 08:09 PM
  #335
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i like the black and red btw
Old Mar 21, 2010 | 08:29 PM
  #336
kthxbai's Avatar
Car: 1985 Z28
well with any luck i can get the motor lifted off the stand tomorrow and start bolting the clutch stuff in. i need to get an alignment tool and sort out which bolts go to which things...
with any luck i could set it in on wednesday, but knowing me ill do something wrong and run out of time haha
then i leave thursday for spring break and its on hold till the second week of april...
thanks for the comments guys
~Steven
Old Mar 21, 2010 | 10:36 PM
  #337
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
with any luck i could set it in on wednesday, but knowing me ill do something wrong and run out of timehaha
~Steven
Just stay late, me and a buddy stayed at school til 10:00 one night changing out his transmission in his Rustang! he didn't think we'd get it done, I told him we just wouldn't leave til it was!
Old Mar 22, 2010 | 04:47 PM
  #338
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
clutch is real simple and should go together pretty quick,my advice would be to bolt the trans to the motor and drop it in as one,ive done it before and once you get it ligned up its cake work to bolt it in.
Old Mar 22, 2010 | 05:32 PM
  #339
kthxbai's Avatar
Car: 1985 Z28
yeah im planning on bolting it all together and going in from the top just like the old one came out.
im going insane over how close i am to finally bolting this sucker in. its been far too long....
i got a clutch alignment tool, and i have a new pilot bearing so i guess first order of business once the engine is off the stand is the pilot bearing, then bolt in the clutch stuff and then the trans with the bellhousing.
anybody have torque specs for all the clutch/trans related bolts?
~Steven
Old Mar 22, 2010 | 06:28 PM
  #340
five7kid's Avatar
Linked in the swap sticky for your convenience.
https://www.thirdgen.org/forums/ltx-...questions.html
(Except it doesn't appear to have the clutch specs )
Old Mar 22, 2010 | 07:10 PM
  #341
kthxbai's Avatar
Car: 1985 Z28
thanks thats about half of 'em. ill try googling or the instructions for an aftermarket clutch to see if i can find a good number for those bolts.
edit: http://torqspecs.com/t-56-transmission-and-clutch/
might help in the sticky
here is what i have found:
flywheel to engine bolts- 74 ft lbs
clutch/pressure plate to flywheel- 22 ft lbs
bellhousing to block- 35 ft lbs
transmission to bellhousing- 45 ft lbs
~Steven
Old Mar 23, 2010 | 12:56 AM
  #342
ericjon262's Avatar
that site has everything but the flywheel/clutch specs!
Old Mar 23, 2010 | 07:43 AM
  #343
five7kid's Avatar
Apparently.
Those numbers look reasonable. I can look in my Haynes if you like. Needs to be soon, though, or this evening - I don't take that book to work with me.
Old Mar 23, 2010 | 07:46 AM
  #344
kthxbai's Avatar
Car: 1985 Z28
ok so it looks like i have all six flywheel bolts, all six clutch/pp bolts, and then...
i have what looks like 7/8 trans to bellhousing bolts and none of the bellhousing to block bolts...
does anybody have the specs or a place to buy these bolts? i think i will try a dealership too....
edit: lots of searches later...
https://www.thirdgen.org/forums/tran...tall-need.html
trans case to bellhousing bolts are M10 x 1.5 x 40
bellhousing to block bolts are 3/8-16 x 2"
stock bolts are all grade 5
~Steven
Old Mar 23, 2010 | 12:50 PM
  #345
five7kid's Avatar
SAE fasteners are referred to by "grade", metric by "class".
Class 8.8 metric fasteners are of similar strength as Grade 5 SAE fasteners.
Old Mar 23, 2010 | 01:49 PM
  #346
Pocket's Avatar
Car: 91 Trans Am
Are you sure the LT1 block uses metric bolts? My friends swap used the same bolts from his old SBC
Old Mar 23, 2010 | 05:56 PM
  #347
kthxbai's Avatar
Car: 1985 Z28
bolts into the block are definitely 3/8-16
i was only missing one of the original eight trans to bellhousing bolts, and M10 threaded perfectly.
got the motor down off the stand today- ready to replace the old pilot bushing with my new bearing. got the alignment tool today too.
i have a new rear main seal in my gasket leftovers, is removing the old one as simple as prying it out with a screwdriver?
Old Mar 23, 2010 | 06:27 PM
  #348
Pocket's Avatar
Car: 91 Trans Am
Yes, you can see the three slots to fit a screwdriver in there
Lube it up and be careful on the install. Be careful not to roll the lip and tap it in as evenly as you can
Old Mar 23, 2010 | 09:02 PM
  #349
kthxbai's Avatar
Car: 1985 Z28
lube as in grease or is there something specific?
Old Mar 23, 2010 | 09:08 PM
  #350
Pocket's Avatar
Car: 91 Trans Am
Engine oil
