T-56 Install - Need bolts and P/N's FAST
Old Jan 29, 2010 | 09:13 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I am getting ready to mate the tranny to the motor but need all the bolts to do it.
Please let me know if I am missing something here and what parts numbers do I need off of summit? I tried to search by car and they dont list ARP bolts for a 95 z28 LT1 T-56 for example. I am doing a LT1/T56 swap into a 92 z
looking for all ARP bolts for these: Do I need anything else for the T-56 and new clutch install?
Trans to bell housing bolts
bell housing to motor bolts (or studs?)
pressure plate to flywheel bolts
bolts to mount flywheel
what are the correct lengths/diameters?
Thanks in advance
Old Jan 29, 2010 | 10:12 PM
Drew's Avatar
Re: T-56 Install - Need bolts and P/N's FAST
Was your donor incomplete? Or are you just looking to upgrade to stronger bolts? For at least the various bellhousing bolts, the stock bolts are already stronger then the aluminum, so why bother with ARP?
Did you already read through that ridiculously long thread and old posts?
I did, but most of it didn't apply to my situation. Now just from my own personal digging, which isn't verified or guaranteed...
Trans to bellhousing bolts are a M10x1.50x40
Bellhousing to engine bolts are the same as they'd be with an auto, 3/8-16 by about 2" long.
Pressure plate to flywheel bolts are specific, there are no upgraded replacements. This thread here https://www.thirdgen.org/forums/tran...ate-bolts.html has a substitute from Fastenal.
Flywheel to crank bolts are the same as any other SBC from what I've read.
Old Jan 29, 2010 | 11:56 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Thanks in advance
Your ARP fascination is fine; they make good product but the OEM bolts are fine for every one of those.
T.A.Y.Q., they are M10x1.5 maybe 40 or 45mm long? 15mm head. (I bought a bunch of these not long ago and have enough to sell a few; they're a slightly higher grade than OEM and have the flange washer)
3/8-16; buy these for any chevy bellhousing to engine
pp to fw are tricky. They too, are 3/8-16 but OEM are a long portion of the shank is unthreaded. If you get bolts that are half-threaded and the unthreaded portion is equal in length to the untreaded portion of the OEM bolts, those work with some flywheels (not all.)
Flywheel to crank are 7/16-20 and again - buy for a manual Chevy app; nothing special here.
Old Jan 30, 2010 | 02:50 PM
Car: 1992 z28
Every nut and bolt on my car is brand new so I figure why re use the old stuff here as well... I actually found the trans-to-bellhousing and bellhousing-to-block bolts so I guess I will just use them. I got tired to trying to search for these guys.
There are no gaskets to RTV or anything needed between the surfaces of the trans-to-bellhousing and bellhousing-to-block right?
Old Jan 30, 2010 | 04:40 PM
Drew's Avatar
Not that I've ever seen... It's bad enough when a transmission sticks to the bellhousing pad of the block without any additional help.
I looked up the various bolts and checked the GM prices. For about what one single bolt cost, I could order 25 from McMaster-Carr and save a couple bucks. If you've got the bolts from the donor car I'd clean them up and use them. You know they'll get the job done without any guesswork. The T56 I bought didn't come with the bolts, the seller had already assimilated them into his bolt bin by the time I came to pick up the transmission.
Old Jan 31, 2010 | 06:52 PM
Car: 1992 z28
Sounds good. Thanks. We'll see how this all comes together in a couple days
Old Feb 1, 2010 | 03:02 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Take my advice and buy some grade 8 bolts at ACE hardware. Here's a thread I started:
https://www.thirdgen.org/forums/tran...-overview.html
Bolts: Clutch PP bolts (Ace hardware, 2" long, 3/8", 16 threads per inch, grade 8) - 6 @ $.69 = $4.14
The ARP flywheel to crank bolts I used are on there too, as well as everything else. The PP bolts form ACE work great. I know cause I just finished my T56 swap last week.
The stock PP bolts are only Grade 5 so the ace bolts are an upgrade and are only $4!
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
red90IROCls1
Aug 25, 2015 06:56 AM
cRoe4
Aug 7, 2015 08:46 PM
