lt1 IAC ?
Old Sep 13, 2009 | 02:33 PM
net_coma's Avatar
lt1 IAC ?
I have an odbi lt1 installed in a 91 RS.
I did not do the swap.
When I start the car it idles fine, it seems that when it goes into closed loop the idle is unstable.
It idles at 750 and at closed loop it drops real low and sometimes catches itself for a min and then goes low again.
The PCM has been tuned by the previous owner, I have the laptop and software but as yet no clue on what it tells me or how to use it. (Tunercat)
Thanks a ton for any feedback.
Old Sep 16, 2009 | 10:27 PM
Firebat's Avatar
Re: lt1 IAC ?
Could try cleaning the IAC. It might not be the IAC though. Closed loop is the only time the O2's are being used by the PCM. May be other sensors too that are only used in closed loop.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
