5thgen Headers compatible with LS3 and Thirdgen Frame
Old Sep 15, 2009 | 03:37 PM
Ethan91's Avatar
Car: 1991 Camaro Z28
Engine: 6.2L LS3 to come
Transmission: 4L60E LVL2 700rwhp
I'm planning on doing an LS3 Swap into a 91-92 Camaro as soon as possible. I have been reading over the LS1 Swap threads, so I know 4thgen Long tubes are out of the question. However what about the 2010 Camaro longtubes? The 5thgen is built completely different than the 4th generation cars, therefore the shape of the headers should be shaped a bit differently. I plan on using Hawks/spohn's K member and a 4L60E transmission.
Old Sep 15, 2009 | 03:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The problem is the 3rd gen subframe that kicks inboard. 5th gens don't do that, from what I've heard, so the headers don't bend in where they need to for 3rd gens.
Old Sep 15, 2009 | 05:05 PM
Ethan91's Avatar
Re: 5thgen Headers compatible with LS3 and Thirdgen Frame
I'll get a high resolution of the 5thgen underbody. Maybe that will help.
Here's what Hawks had to say
You will have to use LS1 swap longtubes made for those swaps. The clearance is so tight, and you will spend $1,400 on a set of 2010 longtubes anyways, we have them for like $699 and up…
I got a fast reply, so I'm not 100% trusting this statement. I can get Doug Thorley long tube ceramic headers for about 500 bucks too Thats kinda why I hope this works even though I doubt it will.
Old Sep 15, 2009 | 05:13 PM
Ethan91's Avatar
Old Sep 16, 2009 | 11:45 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Huh... thats a lot closer to the thirdgen under carrige than I would have imagined. Cool pic...first Ive seen the underside of a 5th gen.
The cats look like they hug the driveline pretty tight, which means the exhaust probably sticks pretty close as well. Ide like to see an under car shot of a 5th gen with long tubes. That would probably offer more insight.
On a side note... MAN I wish we could run duals like that... If I ever get my car on a rotissere like I want to, Im going to completely mod the floor plans to allow for duals/crossover with ample room. That'd be so nice.
J.
Old Sep 16, 2009 | 11:59 AM
Car: 86 Trans AM
Found some pictures... I dont know. Some of them look really close. Others I believe would still be kicked out too far. They might even hang too low... Kinda hard to tell. Might be easy to tweak them though if they just have to pull in some...at least the collectors are pointed in the right direction.
A little comparison with my LS1 and LTs. Ignore my ugly turned in collector extensions.
Even still... The price for those headers is pretty darn high. Around $900+ for the ones that I saw after a quick google search. But Im not up on 5th gen stuff...so Im sure the aftermarket is getting big by now.
J.
Old Sep 16, 2009 | 02:19 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Looking at those pictures, i can say forsure they will not be a direct fit. The problem is the collector goes straight, and you need it to turn inward.
Would be cool to have someone try it, but if your trying to save money, then buying a set of headers to find they dont fit, isnt exactly what you want to be doing
Old Sep 16, 2009 | 02:52 PM
Car: 86 Trans AM
yeah the more I look at them I dont see them fitting at all either. They are pretty darn close, which surprised me.
Ide still like to see someone try..just to see how far off they are out of pure curiousity.
J.
Old Sep 16, 2009 | 05:05 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Agreed justin,
If hedman made a budget 1 3/4 set, it would be perfect to start with to chop up a bit to get them to fit.
Old Sep 16, 2009 | 06:10 PM
Ethan91's Avatar
http://www.youtube.com/watch?v=dZTv-...e=channel_page
I'd like to try, but I don't want to be the 1st one to waste their money
I can get the Doug Thorley long tube ceramic headers for 500 bucks shipped.
Old Sep 17, 2009 | 06:44 AM
Car: 86 Trans AM
You'd probably want to try a set of uncoated headers... since you're most likely going to have to bend/weld/tweak them. After you get them to fit, IF they fit, then have them coated in whatever you'd like.
I really like the exhaust that they put together for the new camaro. Its like a throw back to the 60's cars except for the cats and the fact that it goes UNDER the rear axle area. Like I said..I wish we had the room for something like that. Guess its time to reshape the floors and install an IRS haha.
J.
Old Sep 17, 2009 | 09:26 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Its close but by my guesstimation looking at those pics they are too wide to clear and it looks like the entire bank of primaries would have to be offset inwards to clear. I dont think I'd want to drop 500 bucks on a new set to gamble on making them work BUT... ( theres always a but moment in my posts aint there?geez ) Anyways
BUT
Once these 5th gen headers start popping up used for cheap it certainly appears to be a very mod worthy starting point for a third gen swap. I'd go for it if I could get em for a 100 bucks.
Mind you it would be nice if someone had a set and actually tried to test fit them and posted some pics that would be a bonus. I'm sure that is only a matter of time though.
Also I wouldnt be wanting to mod ceramic coated anything... Dangerous off gas fumes from cutting/welding that stuff not to mention the difficulties of welding previously coated pieces. Start with uncoated stainless or mild steel
Old Sep 18, 2009 | 04:25 PM
TT 68's Avatar
For the money involved I would be inclined to get a set of mid length uncoated headers for a 4th gen and build your own set of full length headers from them.
The pacesetters mid-length I had on my 98 were 1-5/8" tubes. Their full length ones were 1-3/4" tubes.
I'm sure somebody makes 1-3/4" tube mid lengths but they tend to cost a little more since they come with Y-pipes a lot. You can get a set of full length headers for under $300 from summit uncoated.
The hardest part of building a set of headers is getting the ports flat so they seal and getting the tubes clear of the plugs and mount bolts. Starting from some close but not quite right parts will save a ton of fab time.
A box full of mandrel U-bends and some quality time with a chop saw and your welder and you could save a decent amount of money.
Old Oct 20, 2009 | 09:07 AM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Has anyone come up with a solution yet, I too am doing an LS3/L99 A6 swap into my 91' Camaro and need a set of long tubes also, please hit me back if anyone has come up with a solution or idea.
Thanks,
mikesanto70@yahoo.com
Old Jul 31, 2012 | 05:57 AM
Fastime's Avatar
Car: Z/28
Engine: LQ4
$210 ...
http://www.ebay.ca/itm/300748735585?...=p5197.c0.m619
Old Jul 31, 2012 | 09:44 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Man i hope someone has done this or attempted it. Anyone have any more insight? Old thread i know but id love to know out of curiosity and how much trouble theyd be to mess with/modify.
Old Aug 1, 2012 | 05:16 PM
five7kid's Avatar
Yeah, they hang down below the f-body oil pan.
That's a truck pan, and they're lower than it is.
Old Aug 1, 2012 | 08:29 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Just put a skid pad under them and watch the sparks fly, just like in F1- LOL
Old Aug 2, 2012 | 07:27 PM
Pocket's Avatar
Car: 91 Trans Am
Thats my engine in the pic and the biggest problem is the run through the A-arm mounts, then you see how low they are...
5th gen LT headers are out
Old Aug 3, 2012 | 07:57 PM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
what about modding a set of 4th gen long tubes with the slip fit collector? they should be easy enough to position the collector where you want. is the angle of the collector the only fitment problem with a 3rd gen?
Old Aug 3, 2012 | 09:06 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Fourth gen long tube headers hit our frame before the collectors.
Old Aug 4, 2012 | 02:53 PM
Pocket's Avatar
Car: 91 Trans Am
4th gen headers swing out away from the engine and the collectors are pointed at angles away. If 4th gen headers were used, one would have to cut all 8 primaries and point them inward
Old Sep 6, 2012 | 03:02 AM
Podium's Avatar
Will 4th Gen long tubes fit the kmember? I'm willing to redesign my frame rails as I planned on this anyway.
Old Sep 6, 2012 | 03:03 AM
Podium's Avatar
I'm just asking if the frame rails underneath are the obstacle with 4th Gen lts in a 3rd
Old Sep 6, 2012 | 02:48 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
what he said like a month ago
Old Sep 6, 2012 | 04:28 PM
Podium's Avatar
That doesn't answer what I asked
Old Sep 6, 2012 | 05:23 PM
Marc 85Z28's Avatar
I had a set of Doug Thorley shorty 5th gen headers awhile ago. I mocked them up on my 5.3 swap that's in progress. The shorty headers do fit, but it was tight near the steering shaft - about as bad as SLPs headers for the regular SBCs. I don't have an AC/heater box, but I didn't see any potential issues there...
I know it's not THE answer some are looking for as you want long tubes, but hopefully it helps someone!
Old Sep 7, 2012 | 03:07 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
partially frame rails, partially a-arm mounts
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
sreZ28
Aug 14, 2015 07:48 PM
