wiring 94 lt1 FUEL PUMP
Old Sep 25, 2009 | 12:11 PM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I need help I wired my 86 IROC Z 94LT1 engine swap followed Trans Am#5 on the C100 on the firewall the engine carnks to start but I am not getting any fuel form the fuel pump how do I wire the fuel pump from the PCM ?? and what are the wire colors for the fuel pump and are they by the C 100 on the firewall??? for the fuel pump I know I have to add a new fuel pump relay it just wiring I am have in a hard under standing thanks for your help
Old Sep 27, 2009 | 02:45 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: wiring 94 lt1 FUEL PUMP
One side of the relay coil goes to Pcm A7 (red), the other side to ground (opposite the fan relays they receive ground from the pcm and get power feed from the harness), the switch side of your relay you need power and the output to the C100, I believe it *should* be G4, tan/white, however you may want to double check that with a multimeter before quoting me on that.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
