12v ign wire ?
Old Sep 27, 2009 | 08:44 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
12v ign wire ?
i know this sounds silly after doing a whole ls1 swap. i am finishing up my wiring and i need to hook 12v ign to my fuse block. i see that it's a pink and black wire but it doesn't seem a heavy enough guage? connector 207 has one free and was thinking of picking up that wire but there is a thick pink wire on c100 and was wondering if this one is 12v ign? it's for a 1989 iroc. thanks for any help.
Old Sep 27, 2009 | 08:59 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
Re: 12v ign wire ?
i just found a good diagram on austin third gen. it looks like i can use the pink wire f4 on c100.
Old Sep 27, 2009 | 09:32 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 12v ign wire ?
The heavy pink wire in the C100 was IGN to your coil and will be the main source of IGN for your whole harness. I dont know of one large enough to support all of the electronics aside from that one
Old Sep 27, 2009 | 02:41 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 12v ign wire ?
sounds like the best bet would be to use this to trigger a relay from the battery to run everything else. unlimited juice there
Old Sep 28, 2009 | 07:39 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: 12v ign wire ?
BINGO!
You wanna run that thick pink wire to a good relay, and use straight battery power to run all the electrics. Best way to fly.
J.
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
apie2546
Aug 8, 2015 07:12 AM
