ls1 cold air intake
Old Sep 28, 2009 | 09:48 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
ls1 cold air intake
i bought a gto cai(points to left) for my ls1 swap. my question is do you relocate the horns or cut a hole where the evap canister used to be? does it really matter? let me know what fellow swappers have done, thanks
Old Sep 28, 2009 | 07:33 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: ls1 cold air intake
Well what does the kit dictate? Does it place the filter over in the battery tray area? Or does it require the filter to go behind the fender of the GTO?
A lot of guys just leave the filter over top of the battery tray (there is a battery tray on both sides of the car, some cars had the evap/battery switched). Other guys, myself included, cut a hole through the tray and mounted the filter under that. You will get cooler air if you isolate the filter from the engine bay. Even with the filter shoved over and forward as far as it'll go, you'll still pick up hot engine bay air. But the further away you get it, the better.
Can you post a picture of the kit you have? How about a picture of it attached the car so we can see how it sits?
But really, you are only limited to your imagination/creativity. You cant really go wrong...just some ways work a little better than others.
J.
Old Sep 28, 2009 | 08:00 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i have this kit minus the plastic divider. i was thinking of doing what you did and cut a hole in the battery tray.
http://www.knfilters.com/search/prod...x?Prod=57-3044
Old Sep 29, 2009 | 06:45 AM
Car: 86 Trans AM
Ok. So that kit will put you right over by the battery tray area. So you could either just run it like that, or route it down under the tray. If you do that, you'll need an elbow and some more piping to get it down there. I recommend intakehoses.com for all your parts and clamps. They have a great selection, good pricing, and good shipping. Im not sure how big your filter is, but mine was the perfect length to go between the lower air deflector pieces and the underside of the tray. So I didnt even need anything fancy to hold it in place. You can check out my pics for some ideas...but basically just use your imagination to get the filter wherever you want it.
The only probably I see is depending how far over the MAF sensor is, it might make things tight for making the turn down to the batter tray. Its going to be a pain to modify the plastic tubing itself, you might be stuck with working off the end of whats there. So you might just have to run it as is. Ide have to see it on the car.
J.
Old Sep 29, 2009 | 11:28 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I can recommend going through the battery tray - I first did that on my car back around '98 or '99 & ran it that way for years without any problems. (Of course it's been a nice-weather cruiser for years, but still...)
Old Sep 29, 2009 | 02:03 PM
Car: 86 Trans AM
I just drove mine about 45 miles in pouring rain yesterday. Both on slow backroads with puddles and on the highway going 70. No issues what so ever. Pretty protected under that tray, as everyone told me it would be.
My IATs stay super low, and it looks pretty clean without the big filter sitting there.
J.
Old Sep 29, 2009 | 02:57 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
thanks for the help. i will drive it during nice weather so thats not a problem. ghetto i was checking out your build, very nice!
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
