ls1/4l60e swap x member ??
Old Sep 24, 2009 | 08:21 PM
irocbrninrubber's Avatar
I am currently doing a ls1/4l60e swap and wanted to know from those that have, how high is the little bracket on your trans crossmember? I ask because, I have a crossmember for a t56 and if I could find out the dimensions of the mounting bracket, I could just make one and weld it to my t56 crossmember. or how did you mount your trans? Thanks
Old Sep 27, 2009 | 04:04 PM
Re: ls1/4l60e swap x member ??
Anyone? If you did a ls1 swap with a 4l60e, what trans x member did you use?
Old Sep 27, 2009 | 11:13 PM
screeminchicken's Avatar
i got a spohn one .....and for the price i thought it would fit better. it so freeking huge running anykind of decent exhaust is impossible.
there is a member here with a red camaro......who modified the stock one.
if i were to do it again, i would save the money and pay somebody to modify my stock one
Old Sep 28, 2009 | 06:29 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i modified my stock one. i welded a tab about 3" long behind the stock slot.
http://www.speartech.com/
if you go to their 91 project car. i copied them.
Old Sep 29, 2009 | 07:13 PM
Thanks guys, I am glad I didnt spend the money on the spohn x member. I have access to body shop so I will definetly do that. Thanks again.
customblackbird
Aug 15, 2021 10:16 PM
lt1z350
Aug 28, 2015 05:57 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Linson
Aug 21, 2015 02:12 PM
sreZ28
Aug 14, 2015 07:48 PM
