looking for pics of LSx swap with stock exhaust manifolds
Old Jun 28, 2009 | 04:48 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
...im looking for pics of any LSx swap using cast exhaust manifolds...
and what manifolds were they?
close ups showing framrail clearance and oil pan area would be a big help!
thanks very much, Keith
Old Jun 28, 2009 | 06:47 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: looking for pics of LSx swap with stock exhaust manifolds
im using 02 manifolds. check out my build thread.
Old Jun 28, 2009 | 07:03 PM
Car: 91 camaro rs
okay thanks,
im very slowly starting an LQ4 swap that will be turbo'd with my tc-78, and want to run exhaust the conventional way, like i did with my gen 1 sbc in my 91camaro.
thanks again. your car is sick btw!
Old Jun 28, 2009 | 10:36 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
thanks man. i just saw ur old set up .. not bad!
Old Jun 29, 2009 | 11:48 PM
Car: 91 camaro rs
not so great in the asthetics dept. but it got the job done in the HP dept.
im gonna take my time and do hopefully alot nicer of a job on the LQ4 swap/turbo setup,, and get some paint and better wheels/tires on it.
its a long process tho as you know.
Old Aug 20, 2009 | 04:20 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Hey. What happened to the old engine? I saw your car on the forums and here.
Old Aug 29, 2009 | 03:46 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
LOL... I bet the same as me.... (look at my sig)
I am also using 02 trans am manifolds, I have stock k-member and the O2 driver side sensor wouldn't work where they are on the manifold, I plugged and put the o2 in the downpipe, (duels)
Old Sep 28, 2009 | 10:25 AM
screeminchicken's Avatar
John,
What plugs did you use ? sizes? pictures would be great
Old Sep 30, 2009 | 08:01 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
It probably goes without saying around here, but if going with stock manifolds, grab the 01+ camaro/firebird ones as they were redesigned and flow better than the earlier f-body models.
Old Sep 30, 2009 | 10:08 AM
I checked out few of your threads but couldnt find what I was looking for.
Specifically what did u use to cap off the 02 bungs in the manifolds.
would like to see pic of how you extended the manifolds to your y-pipe and where you rewelded your 02 bungs back
Old Sep 30, 2009 | 12:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.speartech.com/
Click on "Company Project Cars", then "91 LS1 Z28 Phase 1" and scroll through the pictures and write-up.
Old Sep 30, 2009 | 12:30 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
get one of these, weld the bung into the y-pipe, and use the plug in the manifold:
http://www.summitracing.com/parts/NGK-91301/
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
transaero
Aug 31, 2015 01:14 AM
timonator
Aug 11, 2015 09:56 PM
