Silly question, but which way do the LSX motor mounts go?
Old Oct 3, 2009 | 06:49 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I'm talking about the stock clamshells that mount to the block itself. It seems as though they're not symmetrical, but rather one side has a double layer for the bolt holes, and the opposite side is not as thick. It looks like the horizontal hole in the rubber part of the mount is offset to one end of the mount too, so I'm assuming getting it on the right way is going to be important. Now, from my crappy cellphone pictures, can you tell if I have them on the right way, or do I need to flip them around upside down?
Old Oct 4, 2009 | 10:40 AM
BlueZee28's Avatar
Re: Silly question, but which way do the LSX motor mounts go?
Bumpity bump.
Old Oct 4, 2009 | 11:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There should be a tab on the backside that keeps them from being installed upside down.
https://www.thirdgen.org/forums/atta...mounts-poly-vs
Old Oct 4, 2009 | 11:34 PM
BlueZee28's Avatar
Mine don't have that tab. They're almost completely flat on the backside.
Old Oct 5, 2009 | 05:52 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i believe the top picture is correct. the metal tab above the rubber bushing faces up
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
