3rdgen LT1 Cruise functioning cruise
Old Oct 5, 2009 | 11:47 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have my swap done on my car and I removed the vss buffer and just hooked the speed output from my 94-95 LT1 PCM to the speedo and cruise control wires under the passenger side dash where that buffer once resided. As you might expect the cruise doesn't like the same 4k pulse as the speedo. Cruise works just fine up to about 54mph but no higher. Does the LT1 PCM have a 2k pulse output for cruise or is the LT1 cruise a 4k pulse. Anyone else running cruise control on their LT1 swaps. What did you do to get it to work.
Brian
wigmobile
Feb 26, 2025 02:56 PM
Elephantismo
Feb 13, 2019 12:51 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
ULTM8Z
Sep 16, 2015 09:15 AM
