help with third gen LT1 swap
Old Oct 4, 2009 | 08:33 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
im tryna figure out what to do for a lower radiator hose,can anyone help? im using my stock 87 firebird radiator thanks!
Old Oct 5, 2009 | 05:35 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: help with third gen LT1 swap
IIRC a 92 vette lower and 95 camaro upper.
Old Oct 10, 2009 | 05:28 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I also seem to remember the '92 Corvette lower hose. For the upper, I think it may be a '94 or '95 Camaro hose, whichever one has the "y" design.
Old Oct 10, 2009 | 10:35 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
get the one without the y design and bypass your tb
Old Oct 13, 2009 | 10:12 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i got the upper hose from a 95 roadmaster and fit right on with some trimming now i just need to get a vette lower hose,thanks for the help.
also on the back of my LT1 heads i noticed a big bolt with aluminum lines runnin out of them but mine were cut =( can i block these off? idk whether coolant or air goes thru them? any help would be great
Old Oct 13, 2009 | 02:05 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I would put the coolant/steam tube on, but I know some guys have blocked them off. They may chime in.
Old Oct 13, 2009 | 04:07 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
where is the coolant stam tube located? is that the 2 lines coming off of the rear of the heads?
Old Oct 13, 2009 | 05:04 PM
Car: 1992 camaro
Axle/Gears: 3:73
Yeap and connects to the tb.
Old Oct 13, 2009 | 06:02 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
but if i just crimp them off it will be ok?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
