Engine mounts???
Old Nov 15, 2009 | 05:52 PM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
Engine mounts???
Im swapping my 305 out of my 91 for an LT-1...does anyone know the exact measurements to mounts have to move or do i even have to move them?
Old Nov 16, 2009 | 02:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The engine mounts don't have to be moved. Use the 3rd gen mounts on the engine.
Detailed in the LT1 swap sticky.
Old Nov 16, 2009 | 03:03 PM
Car: 91 camaro
Engine: LS3
Re: Engine mounts???
i dont mean to doubt what your saying just wanna make sure before i put it in..why is it that everyone is talking about the k-member being in the way of the a/c compressor when the mounts sit all the way foward on the k-member? also i have a t-56 im putting in this will not interfere with anything?
Old Nov 16, 2009 | 03:06 PM
five7kid's Avatar
AC compressor is a different question from the mounts.
Ditto T56 mount vs. 3rd gen tranny.
Old Nov 16, 2009 | 03:19 PM
Car: 91 camaro
Engine: LS3
man i am lost....
Old Nov 16, 2009 | 05:45 PM
five7kid's Avatar
Stock 3rd gen SBC mounts will bolt to the LT1 block. Nothing has to move.
However. . .
The way the f-body LT1 AC compressor was mounted interferes with the 3rd gen K-member - the K-member was completely changed for 4th gens. You can either notch and box the 3rd gen K-member, or get an aftermarket tubular K-member if you want to use the f-body LT1 AC compressor as-is.
The LT1 T56 requires a different or modified crossmember than stock 3rd gens. Such as http://www.spohn.net/shop/1982-1992-...ossmember.html
Old Nov 17, 2009 | 10:39 AM
Car: 91 camaro
Engine: LS3
awsome just bought the tranny mount, i decided to hold out on the a/c so im eliminating it for now...just to get the car done but thanks man that was a big help!!
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
