fuel lines?
Car: 85 IROC-Z
fuel lines?
im going to be putting an lt1 in my 85 iroc and was wondering about the fuel lines. my car originaly came with a carburated 305 and im not sure if those lines can hanlde the pressure or volume that its goin to need? also about putting in an in tank fuel pump, i got a walbro 255 and im not sure if the lines at the tank are able to run this set up? if u have pics of this set up please post but any help would be nice
Transmission: 4L80E/4L80E
Volume, no problem. They are 3/8" & 5/16", same size as LT1 (I will accept correction on the return line size, as I am going off fuzzy memory for that).
Pressure is not a problem for the hard lines. For any rubber under pressure, you'll want to change it out for EFI hose.
Re: fuel lines?
Also, just swap the sending unit with one from any EFI 3rd gen. Carb lines had hose clamps on both the feed and return. EFI systems operate at a pressure above what most clamps are rated at. EFI sending units have saginaw threaded fittings
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
