NEW lsx swap header's
Old Jan 11, 2010 | 12:44 PM
battz86's Avatar
Brand new and still in box. Hawk's SSW lsx swap header's. 1 3/4 w/ 3in. coll. Polished and will come with new bolt's. $650 shipped.
Old Jan 18, 2010 | 06:02 PM
Yahtzee's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
Re: NEW lsx swap header's
You say these are 1 3/4 with 3" collectors? How come Hawks doesn't advertise this size on their site?
Old Jan 18, 2010 | 06:27 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
let me know how you get around the trans crossmember
Old Jan 19, 2010 | 03:05 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
tempting!! ..
Old Jan 19, 2010 | 08:16 AM
battz86's Avatar
Sorry guy's. Sold!!
Old Feb 2, 2010 | 04:29 PM
hawksthirdgen's Avatar
Premium Sponsor
HEy guys just wanted to post up and let you know we do still off these headers in a 1 5/8 primary and a 3in collector, most guys that have a cam only, heads cam comdo or even a small cube stroker will do fine with these headers as long as we are below a 6800 RPM red line/shift point. We also off the 1 3/4 primary as well for a little more money and may be coming out with a 2in primary in the future also we will be working on y pipe for the 3in collector with our new tranny cross members we offer on our website which also help you the customer for more clearance with a self built y pipe. Keep a check on the site and let us know if we can help further also both headers work fine with a auto trans.
Thanks,Bruce
www.hawksthirdgenparts.com
864-855-2694
Old Feb 2, 2010 | 09:11 PM
Z28FAST1's Avatar
The headers with 3 inch collectors scrape everywhere. My car is lowered so that doesn't help much either. I guess you have to sacrifice sometimes.
Old Feb 3, 2010 | 04:50 PM
Premium Sponsor
Hi,
Do you mean your Y pipe is scrapping or your header collector I have never seen a LS swap car scrape the collector, let me know if I can help.
Thanks,Bruce
Old Feb 8, 2010 | 12:41 AM
Z28FAST1's Avatar
Originally Posted by hawksthirdgen
Hi,
Thanks,Bruce
The actual headers scrape, right where the primaries merge into the collector. They seem to hang lower than the chassis. I'll try and snap some pics soon, using the hawks motor mount as well.
Old Feb 8, 2010 | 08:36 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
That is a big gripe I have about them. Here is a pic of how far they sit below the front subframe (SPOHN k-member):
Old Feb 8, 2010 | 09:12 PM
Z28FAST1's Avatar
Same as mine, i didn't have a ruler but I estimate they sit 2.25 -2.5 inches from the ground. My y-pipe is tucked in higher than the primaries. I would be happy if they tucked in an extra .75 to a whole inch.
Old Feb 9, 2010 | 06:36 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
wow, i cant believe how low the LSX headers sit. i would have never believed they hung that low compared to reg sbc headers
[IMG][/IMG]
I would have thought that your y pipe was scraping!!! its almost impossible to go through that spohn x-member!!
Old Feb 9, 2010 | 08:43 PM
Omega's Avatar
Engine: LS1 / LS3
CRAMOS78 did you really have to put salt in the wound? That is how the hawks headers SHOULD sit!
Old Feb 9, 2010 | 11:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
wow the ls1 headers that I made for my car do not sit that low at all, in fact they are barely lower than the oil pan, just in case I came down on them hard from a wheelie. Now I'm making a bigger set, they're for sale if anyone is interested
Old Feb 11, 2010 | 09:26 AM
Premium Sponsor
Hi Guys, the LS1 swap headers we originally did where worked around the Spohn cross member which did not offer very much ground clearance, which is the reason why we never did a 3in y pipe so when we did the SBC header we worked the header collector and y pipe around a STOCK crossmember so therefore the header and y pipe was able to stay up more than on the LS header. BUT as you can see by the pics above on the SBC header WITH the SPOHN cross member there is NO PLACE to run the y pipe it does have more header collector clearance but NO PLACE TO RUN THE Y PIPE.
Fast forward to last year and HAWKS came out with NEW T56 and 4L60E cross members that give MUCH MORE ROOM for the y pipe and we will eventually have 3in y pipes for the 3in collector headers, we have several cars at the shop that have 2.5in and 3in y pipes with the NEW cross members that have great ground clearance, now if you have a car that is slammed on the ground with long tubes and a y pipe you have to be willing to give a little somewhere,let me know what we need to change and I will try to work with you all the best I can.
Also if anyone is doing a swap call the office and I will give you a list of parts conversion and suspension that will give you the most ground clearance so you dont get in the middle of a swap and two things will not work great with each other.
We are also working on a 2in primary 3in collector ,3in y pipe into a 3.5 exhaust single inlet/outlet complete exhaust system with all vbands for easy install and removal of the y pipe and exhaust system ( this will only be sold as a COMPLETE SYSTEM from header flange to muffler tip but quality will be TOP notch
Below are some pics of our 1 5/8 headers with 3in collector and y pipe and a 4in magnaflow exhaust on a stock hieght 89 IROC LS1 4L60E swap.
Attached Thumbnails NEW lsx swap header's-lsswap-pic.jpg   NEW lsx swap header's-lsswap-pic.jpg2.jpg   NEW lsx swap header's-lsswap-pic.jpg3.jpg
Old Feb 11, 2010 | 08:18 PM
Z28FAST1's Avatar
^^^ Thanks for the input and info.
I would love to get the clearance similar to the vehicle posted above. i'm not too sure what you mean by "stock height" because swapped LSX car’s w/lighter engines, are raised by 1-1.5 inches with stock springs . In order to reach factory “stock height” you have to lower your car w/ the Eibach pro-kit or something equivalent. To achieve a more aggressive “sports stance” you need to go with the Eibach Sportlines or equivalent which lowers the car 2.25 inches. I went this route and its become a nuisance to drive with my SSW long tube headers w/3 inch collectors.
Can you post pictures of the above vehicle’s stock height?
Old Feb 12, 2010 | 09:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you've got a new crossmember that gives more room, how about a set of LS1 headers & y-pipe that sit up higher? This would also be a godsend for those of us who plan to make our own crossmember and y-pipe too.
I've had my single 3" exhaust with my TPI 350 scrape way too often... I can't imagine having those long tubes sit that low on my car.
Old Feb 15, 2010 | 12:20 PM
Premium Sponsor
Hi,,
I will try to get you guys some more pics later, we do offer the new cross member for extra y pipe clearence is in stock ready to ship, but what alot of guys dont understand is there are so many options for suspension choices, exhaust choices, and trans cross members it is hard or next to impossible to get a y pipe that fits most cars, then when you do come out with a y pipe that fits most you get someone that gets one that has pieces already on there car that the y pipe was not designed around then they get on public forum and trash the new product then all the customers that are thinking of the new product are scared of it and dont purchase, so we have been hesitant to come out with the new 3in y pipe because of the above reasons, I would kindly ask the customers doing the swap to understand every car and every swap is slightly different keep and open mind and understand some things sometimes need to slightly be modified or changed for all of the aftermarket parts to coinside together, if any of the people on the board are looking to start a swap and have not gotten anything yet feel free to call and I can give you a list of things that all work best together as we have done 30-40 Ls/3rd gen swaps in the past so we have about tried it all. Again thank you everyone for your continued support and if you have any questions dont forget to call or email the shop.
Thank you ,
Bruce Hawkins
864-855-2694
Old Feb 15, 2010 | 02:25 PM
Jim85IROC's Avatar
I realize that you can't make everybody happy, but at least to me, I'd rather deal with y-pipe issues instead of header issues. Getting the headers up where they belong might make it more challenging to fab up a y-pipe. A y-pipe is something that can be done affordably by a local exhaust shop. Headers... not so much. Headers are what we really need to have available as a bolt-in.
On that note, maybe stick with the long tubes you've got already, but come out with a mid-length set of headers that dumps up higher. And as long as I'm reading off my wish list here, maybe offer a more affordable set in steel? A lot of us want to coat the headers anyway, so not having to pay a premium for stainless would be nice.
By the way, are you planning to go to Carlisle this year? I've missed you the last few.
Old Feb 15, 2010 | 04:58 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Part of the reason i'm shying away from an ls swap is because of the lack of options on headers. stock f-bod manifolds or $800 longtubes, nothing in the middle.
Old Feb 16, 2010 | 01:17 PM
screeminchicken's Avatar
Hi,,
Thank you ,
Bruce Hawkins
864-855-2694
would you buy back unused spohn trans X-members in lue of the new set of X-memebers you guys put out. I could install them and review them for ya !
Old Feb 16, 2010 | 03:28 PM
Premium Sponsor
Hi,
What torque arm do you have on the car?? Feel free to call me at the shop.
Thanks,Bruce
Old Feb 19, 2010 | 10:37 AM
Premium Sponsor
Hey Guys, here are a few pics of the latest LS swap header/y-pipe combo. The y-pipe is a 3" y-pipe with our 3" collector LS swap headers. The crossmember is our maximum ground clearance crossmember... see attached pics.
Thanks, Steven
Attached Thumbnails NEW lsx swap header's-img_1338.jpg   NEW lsx swap header's-img_1347.jpg   NEW lsx swap header's-img_1350.jpg
Old Feb 19, 2010 | 03:55 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
how long until the y pipe is for sale?
Old Feb 19, 2010 | 03:58 PM
Omega's Avatar
Engine: LS1 / LS3
That setup looks tons better than your previous y-pipe. I presume that is your original version of headers.
If you do end up selling a set of more tucked up headers for those of us that can and will fab our own y-pipe, will you accept an unused parts return for them?
Old Feb 19, 2010 | 04:10 PM
Premium Sponsor
Hi,
this is actually the later polished headers on this car that FITS GREAT BTW and a custom in house built y pipe, the y pipe we will come out with in the spring will be for the polished header only and we are also coming out with a BIG PIPE SYSTEM later in the year I will post more when I have it.
Thanks,Bruce
864-855-2694
Old Feb 19, 2010 | 07:27 PM
Omega's Avatar
Engine: LS1 / LS3
Hi,
this is actually the later polished headers on this car...
Weird, I bought a set from you a few weeks ago and they have a build date of early '09. They are not shiny, not that I mind, but what is the difference?
1984HO
Mar 19, 2021 11:59 AM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
