Does the PCM needs cooling?
Old Jan 25, 2010 | 12:53 PM
4strokeforce's Avatar
I'm doing an lt1 swap in my Camino -69. I know my car isn’t an f-body, but I'm sure you can help me with my problem.
I want to make a clean installation in my car with all the electric stuff hided. I'm thinking of putting the PCM under the dash inside the car. Is it a possible solution or will the PCM need cooling to work properly? I don’t know how warm it will be and if it needs cooling.
Hope you can help me!
Old Jan 25, 2010 | 05:01 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Does the PCM needs cooling?
As long as its not directly laying on a header or heater core, it will be just fine
They are weather proof, designed to survive a hostile engine bay with no cleaning or maintenance. Underdash will be no problem
Old Jan 25, 2010 | 10:02 PM
Firebat's Avatar
Maybe check out pro-touring's forums. Its a website mostly for 60s and 70s V8 cars with modern goodies. Could see what they think as far as location because I'm sure some of them have done LT1/LS1 swaps in their 60s Camaros. But yeah, shouldn't have a problem with the PCM. Here is the link for that website: http://www.pro-touring.com/forum/index.php
Old Jan 29, 2010 | 03:25 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I installed the LT1 PCM under my dash on the passenger side and ran it for a year with no difficulties. The engine compartment has to get much hotter than it gets behind the dash, so if anything it should enjoy its new home :-)
Old Jan 30, 2010 | 02:42 AM
Thanks for many great answers. I'm going to place the PCM at the same location as JeremyNYR did.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
