ls1 swap
Old Feb 3, 2010 | 07:31 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
ls1 swap
i want to do a ls1 in my iroc and i need to know everything that is needed to dp and a ls1 swap in my camaro.
motor mount
harness smog (smog im in calfornia)
i need everything and some estimates
thanks in advance..
Old Feb 4, 2010 | 02:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure exactly what you mean there.
First, check the LS1 swap sticky in the top section of this forum (I moved this to the LSX and LTX engine swap sub-forum) for the basics of the LS1 swap.
You will need to go through the California "motor change" process. They will take the information about your engine (year, model, etc.) and determine what emissions equipment you need, then inspect your car for the installation and operation of that equipment. If that is satisfactory, they'll give you a new barcode and bless you until your next required test/inspection. After that, you can take it to a "regular" test station.
You will need all of the equipment that was installed from the factory in the car the engine is to have come from. That will include the computer, catalytic converters, EGR & A.I.R. systems, evap system (part of the fuel tank and engine), sensors (O2 et al), and even the OBD II connector. You can use aftermarket parts if they are C.A.R.B. certified.
Cost is a crap shoot. First, you need the parts from a donor car. If you aren't going to be doing the installation yourself, a shop is going to charge an arm and a leg to do this custom work - probably more than a 4th gen would cost you.
Old Feb 4, 2010 | 04:14 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: ls1 swap
Five7kid, Im very impressed by your patience writing all this and informing this guy about what has been covered a billion times. I feel that if someone isnt even willing to search a bit on its own, hes not ready for this swap. Hats off to you sir :chug:
Old Feb 4, 2010 | 09:08 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Re: ls1 swap
so what are u saying , that u think i have not researched this or what
Old Feb 4, 2010 | 10:09 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: ls1 swap
well thats my take on what he wrote
anyway there are lists here that go into alot of detail. I would be happy to give you info on any specific item you dont understand or the details seem to be unclear
Old Feb 4, 2010 | 10:50 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Re: ls1 swap
Give the dude a break! He only has 17 posts! Good luck with your swap man, there is alot of useful info here and the people are generally nice and willing to assist you!
Old Feb 5, 2010 | 05:31 AM
kevinc's Avatar
Car: 1982 Z28
Re: ls1 swap
He makes a good point guys, his original post didn't ask anything at all. Just stated that he needed to know everything.
When I read it, I just shook my head in agreement and moved on.
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
