I need to clear a few things up.
Old Feb 7, 2010 | 07:48 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I am in the midst of my LS1 swap. The engine is in, HAWKS are on (nice looking, but they destroyed my ground clearance!), wiring is next. I have a few things I need to set straight.
The C100/power distribution connector. If I have this correct, the RED A4 pin is battery power (constant), PPL B4 triggers the starter, and PNK F4 is the ignition power. So, once the key is in the run position, I can use F4 to feed the fuse box for all that I need?
In the following pic, what are A,B,C, and D? I know, I know, I should have labeled them. I think they are..
A - Wiper control
B - ?
C - Fuel pump relay
D - Some other relay, or vise versa
Thanks for your help
Old Feb 7, 2010 | 08:27 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: I need to clear a few things up.
I think "a" is actually the electronic spark control module. one relay is the fuel pump, one is the cooling fan, I'm not sure what the other part is.
Old Feb 7, 2010 | 08:45 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
You should have 1 fuel pump, 1 primary fan, 1 secondary fan. Thats my guess... You may have to trace them out.
Old Feb 7, 2010 | 08:51 PM
ericjon262's Avatar
assuming it's a TPI car.
Old Feb 7, 2010 | 09:04 PM
Omega's Avatar
Engine: LS1 / LS3
Yes, it is/was a TPI car.. an 89 Formula.
Can't trace it easily, the harness is now lacking most if not all TPI related wires. It seems in my fragmented work schedule, I have forgotten some things and or a label has fallen off here or there.
I'm going to use a 4th gen fuse/relay block so "c" and "d" are not crucial, but I think "a'' and "b" could be. Is "a" the headlight module?
Old Feb 8, 2010 | 04:55 AM
Pocket's Avatar
Car: 91 Trans Am
I was going to say your 89 will have all the necessary fuses/relays to keep from using a separate fuse block
With the 4th gen block, you can remove all of those. It will have sufficient relays to support the engine and components. For future reference, the relay body made little difference on function. You can rearrange the 3 and as long as something is plugged into them the function of each component will be the same
A is ESC
Old Feb 8, 2010 | 09:23 AM
Transmission: 4L80E
Can't all remember all the wires on the c100 connector that I mod'd. You may do a search and find out what goes where. Theres a buch of info on here.
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
One of those relays is the maf burn off relay
Old Feb 8, 2010 | 12:51 PM
Pocket's Avatar
Car: 91 Trans Am
This thread has all year C100's
https://www.thirdgen.org/forums/ltx-...formation.html
The only mandatory wires are the two big red power wires and one big pink IGN
The rest are gauges or non-reused electronics
Old Feb 8, 2010 | 07:22 PM
Omega's Avatar
Engine: LS1 / LS3
Thanks Pocket, I skimmed that at one point, but I never read the whole thing.
What/where is H02?
*EDIT* Is it in reference to the LS1 schematic you posted?
Old Feb 8, 2010 | 07:38 PM
Pocket's Avatar
Car: 91 Trans Am
Newer O2 sensors are heated. Short hand is HO2 so they arent confused with the direct to ECM/PCM controlled older non-heated style
If you are using the 4th gen fuseblock, then t will have an IGN relay. You run the C100 IGN wire to power the IGN relay in the block. The rest of the wirng will have the proper fuses and connections to run the HO2s along with all the other electronics and sensors
Old Feb 8, 2010 | 08:22 PM
Omega's Avatar
Engine: LS1 / LS3
Ok, so I was correct, the PNK IGN wire is from C100 to whatever needs it... relay or otherwise.
1992rs/ss
16
Jan 28, 2016 09:58 PM
stalkier
Aug 21, 2015 01:54 AM
Bob88GTA
Aug 18, 2015 03:31 PM
