Emissions block off plates
Old Feb 12, 2010 | 07:43 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I bought a set of block off plates - 3 came in the set. I know the two that go on the back on the LT1 intake but where does the third one go? It only has one hole for one screw/bolt. I have no idea where it goes or if I even need it.
Also, does it matter if you use the gaskets that come with the set? I am just planning to use RTV to seal these up and not worry about no cheapo gaskets.
Anyone? Pic would help if you got it.
Old Feb 12, 2010 | 11:31 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Emissions block off plates
It should go to the manifold. If you're using a SBC exhaust either headers or manifolds, the hole wont be there so the plate cant be used
RTV will be fine for anything on the intake. If its attached to the exhaust anywhere, the graphite gaskets are required
Old Feb 12, 2010 | 11:48 PM
Car: 1992 z28
Cool. Thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Kenwood
Sep 11, 2015 12:50 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
