5.7 LS1 bored and strocked
Old Feb 13, 2010 | 10:06 AM
bad67ss's Avatar
Car: 92 Z28 LS1 4L60E swap
I am almost done installing my 5.3L and came across a pretty good deal on a LS1 short block that needs rebuild. Can these be bored and strocked to a 6.0L or should i just wait for a 6.0 shortblock to roll around. I am looking for more power to build and install next winter.
Old Feb 13, 2010 | 10:47 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Re: 5.7 LS1 bored and strocked
You can't bore it to the 4" bore of a 6.0L. Max you can go is around 3.905 (a little over that I think). Now you could resleeve it and go as big as you wanted...but that means money.
Old Feb 13, 2010 | 01:02 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You can stroke a LS1 to 382 cubes. Or you can get the world jugs and make a 427.
Old Feb 13, 2010 | 01:09 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just turn a 6.0L into a 402/408 and call it a day, I wouldn't put a dime into a ls1 when the price of ls2 shortblocks has dropped so much if you want to stay aluminum. Me I'd rather just buy up the 6.0L or wait until early december when the sponsors on ls1tech have their stroked shortblock sales and take over several hundred. I've gotten a few for people during that time for great prices.
Old Feb 13, 2010 | 01:16 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
how much hp/tq can i make out of a direct injected 572?
Old Feb 13, 2010 | 01:37 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
If you mean direct-injected as in the new F*rd Eco-Boost engines, then the answer is "More than you can put to the pavement on a street tire!"
Old Feb 13, 2010 | 08:58 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Actually, you can't direct-inject a 572 without designing some new heads to take the injectors. But for less money, you can do a 408 LQ4 and have less weight, more mpg, and less emissions.
KO1
16
Oct 15, 2015 05:00 PM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
