Pocket's LSx swap
Old May 8, 2010 | 08:57 AM
  #151
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
Re: Pocket's LSx swap
This Comp Nine website is one of the best research/lookup resources I have ever seen. Thanks for the pointer...
Mike
Originally Posted by Pocket
PN is off compnine's website and its been correct so far with the PNs. The power block is common on the vortec S10's and old LO5 1500 series trucks. Only the later model S10s got the cover for some crazy reason. It mounts on two studs with some plastic nuts holding it on. I hate those with a passion so I use normal bolts to attach the cover with the block as seen
Old Sep 23, 2011 | 11:17 AM
  #152
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
pocket your a genius man i love how you cleaned up the engine bay im doing that once i get my air inake all fixed up.
Old Jan 21, 2012 | 09:10 PM
  #153
1hotbird's Avatar
hey pocket what all did u use for the intake air filter setup?
Old Jan 28, 2012 | 09:58 AM
  #154
Pocket's Avatar
Car: 91 Trans Am
1x 90*
1x 45* cut in half
1x Spectre 4" filter
2x 4" silicone couplers
Use 4" intake stuff for the 85mm truck MAF and 3.5" stuff for the 75mm car MAF
Scamo-2.8
May 20, 2016 07:01 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
C409
Sep 1, 2015 03:42 PM
AkDrifted
Aug 17, 2015 07:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
