89 camaro rs v-6 swapping to 5.7l LT1
Old Mar 8, 2010 | 07:22 AM
new2thirdgen's Avatar
Car: 89 camaro rs
Engine: v-6 soon to be v-8
welcome everyone. Well i have owned my 89 camaro for about a year now granted only driven for 6 months.At the very end of the summer season my transmission was acting up which i think it had something to do with a vacume problem because of the symptoms.Anyways I have been reading post about swapping v-6 camaros into a 5.7L v-8's.Seems as though all the threads about swapping new ones are old and new followed through. Today I bought my 5.7L v-8 it is still in the 1996 caprice classic 9c1 old cop car. Can people on here that have done the swap help me out on what i will need to actually do the swap. I really dont want to find out half way through I forgot something.I will get bak on here later on this evening. i think its time for a new updated version on the v-8 swap,lol
Old Mar 8, 2010 | 07:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
First, I moved this to the LTX and LSX subforum where topics like this are discussed.
Second, did you read the LT1 swap sticky in the top section of this forum? Also, parts of the V6 to V8 swap sticky apply, such as what to do with the engine mounts on the K-member, and the need for a V8 radiator and transmission (hope you're getting the tranny from the Caprice as well).
Old Mar 8, 2010 | 10:39 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Re: 89 camaro rs v-6 swapping to 5.7l LT1
you will be able to fine all your info on this sight its been very helpful for my LT1 swap as well,good luck
Old Mar 8, 2010 | 08:51 PM
Car: 89 camaro rs
Thank you for the starting information. I have read some things about swapping the engine just still triing to figure how the web site works. Iam going to use the transmission from the caprice plus i was thinking on using the suspention too if it works.Most theads on here stop with out finnishing their stories. this site has inspired me on the LT1 and plan on using everything i can from the caprice.what do i need for the spedometer? do i need to change out mine and what would work. I 'am just getting all my ducks in a row and plan on swapping in three to four months. any information will help
Old Mar 8, 2010 | 10:50 PM
five7kid's Avatar
I believe the '89 Camaro was the first year of the electronic speedometer (no speedometer cable). So, matching the pulse count is the only issue driving the speedometer off of the Caprice transmission, if that's the case. If, however, your car still has the speedometer cable, you will need to get a speedometer drive box that converts the PCM output pulses to mechanical rotation.
You will need a means to mount the differential torque arm since the Caprice transmission doesn't have that provision. I don't know off the top of my head if the '96 4L60E tailshaft housing will swap with a 3rd gen TH700 tailshaft housing, but if it will, you're good to go. If not, either find an f-body tailshaft housing, or provide some other means of hooking up the torque arm.
Old Mar 9, 2010 | 02:27 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
ok here goes...I swapped my 3.1 for a carburated 350. so this is what i have, you need to change the crossmember to the tranny, I welded ends on mine and drilled new holes.that works too. the placement of the v8 is difrent then the v6. but all the holes are there to swap the crossmember. the driveshaft from the v6 wont work. I cant remember if it was too long or short. you can get one to fit or modify the one you have. the tailshaft needs to be swaped like previously stated on another posting. or get a difrent tranny. check the wiring to the tranny to see if the plugs are the same . I think they are. you can also get aftermarket programable speedos. how they install i dont know , I havent done that to mine yet
Old Mar 9, 2010 | 02:33 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Originally Posted by aremy10
ok here goes...I swapped my 3.1 for a carburated 350. so this is what i have, you need to change the crossmember to the tranny, I welded ends on mine and drilled new holes. that works too. the driveshaft from the v6 wont work. I cant remember if it was too long or short. you can get one to fit or modify the one you have. the tailshaft needs to be swaped like previously stated on another posing. or get a difrent tranny. check the wiring to the tranny to see if the plugs are the same . I think they are. you can also get aftermarket programable speedos. how they install i dont know , I havent done that to mine yet
now for the engine, you need to swap motor mounts, top and bottom, from the caprice to the camaro. also need to swap the computer from the caprice to the camaro, I cant say if the connectors are the same. also check the wiring plugs on all accesories , the alturnator may be a 2 prong or a 3 prong, and could be on the opposite side of the engine. you can reroute the wires to the side you need em on. as far as the sencors go ,make sure all the plugs are the same, if not i do beleive that the most of the v6 ones will work on the v8, not sure about the carb sencors though.
Old Mar 9, 2010 | 02:36 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
ok the cooling system, the v6 radiator will work with the v8. ive already investigated that .according to factory parts the v6 and v8 radiators are the same. it is also how mine is set up, I use a 160 degree thermostat with the v6 rad. and elec. fan. the caprice probebly has electric fan, but if not , just take off the clutch fan and put the nuts back on to hold the pulley. this is how mine is set up and it works good
Old Mar 9, 2010 | 02:42 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
ok the cooling system, the v6 radiator will work with the v8. ive already investigated that . it is also how mine is set up, I use a 160 degree thermostat with the v6 rad. and elec. fan. the caprice probebly has electric fan, but if not , just take off the clutch fan and put the nuts back on to hold the pulley. this is how mine is set up and it works good
as far as the fuel pump goes , the camaro pump will probebly work , i m not sure of this because i dont know what pressure the lt1 needs , I think the v6 pump pushes between 20-35lbs
for the exhaust, the v6 Y pipe i don think will work, the one in the caprice might fit right in, but you can also modify that to fit, just something to check.
i think thats it . if i remember any more ill let ya know. good luck
Old Mar 9, 2010 | 03:17 PM
five7kid's Avatar
Okay, now to correct all that:
Yes it does work, if you locate the engine properly (as in, use factory mounts and holes).
Irrelevant. If you use the engine, transmission, and harness from the Caprice, it will all work.
Again, irrelevant. Use the stuff that comes with the engine. All you will be rewiring are the connections to the car itself, which is well documented in the LT1 swap sticky.
That is only true for the 3.1 V6 cars. '89 would be the 2.8 V6, so a V8 or later V6 radiator is needed.
The V6 pump operates at a higher pressure, but it won't supply sufficient volume for an LT1. Plan on replacing it. A TPI replacement pump will be fine, or you can upgrade to something like a Walbro 255.
As stated in the V6 to V8 swap sticky, assume all of the V6 exhaust has to go. The good news is 3rd gen V8 stuff works.
Old Mar 9, 2010 | 03:54 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
again sorry for the mistake. didnt realize 2.8 .
the 3.1 mounts are diffrent and wont work ,because the bolt pattern wont work with the block
oops my mistake, I forgot that the first 3 trannys i put in my car were th350. so i did have to change the driveshaft. but not with the 700r4..forgot to mention mine was swapped from a 3.1.didnt know they didnt put that motor in the 89.
also my mistake, i didnt realize that a v6 computer could run a lt1 motor . sorry about that too
sorry again forgot to say 3.1 rad.
again i said i didnt know
ya said that i didnt think it would work.
Old Mar 9, 2010 | 04:03 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
again i dont know much about the wiring for that swap
these are the things i encountered when swapping my 3.1 with a CARBURATED 350
Old Mar 9, 2010 | 04:06 PM
five7kid's Avatar
Appreciate that your swaps were carbureted.
I didn't say a V6 computer would run an LT1. I said the computer ("stuff") would come from the Caprice. Engine, transmission, accessories, harnessing, sensors, and PCM (computer) should come from the Caprice. Wouldn't hurt to pull the fuse/relay box as well. The harness connectors you disconnect to remove all that from the car will then be spliced into the Camaro.
FWIW, the 2.8 V6 was used from '82 to '89. In '90 the 3.1 came out, and the cooling system modified so the same radiator could be used for both V6 and V8.
Since your swaps used TH350's that would explain why you couldn't use the TH700 driveshaft, which would be too short. Trivia: The "long" tailshaft TH350's (9" vs. the normal 6") can use the TH700 driveshaft; and the early ('82-'83) 3-speed automatic and 4 speed manual driveshafts are the right length for a short tailshaft TH350.
Old Mar 9, 2010 | 04:16 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
you had some realy good info on the electronics. i just always prefered carburated.
ya the th350 tranys were great off the line, but the rearends just werent geared for them and i didnt want to change rearends or gears. so then i went with the 700r4..much better. sometimes i think of goin with fuel injection but i cant stand the headache with the electronics..
Old Mar 9, 2010 | 04:30 PM
Pocket's Avatar
Car: 91 Trans Am
If you spend some time to familiarize yourself with the schematics and are thorough with the harness, the electronics are extremely accurate and reliable, much like your factory electronic gauges. All electric
Old Mar 9, 2010 | 04:34 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
HAHAHA... move to California... after your first smog inspection, you'll be camping out at the local junk yard that same night waiting for it to open so you can buy a TPI set up...
Old Mar 9, 2010 | 06:50 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Move the motor mounts to the front holes on the crossmember, you have to relocate the brake hardlines to clear the one set of holes. You can reuse your crossmember for the transmission and the driveshaft as well. Since you have a 2.8 you will have the correct lines like a TPI car to come up and provide fuel and return to the back.
Go with a Walbro 255lph fuel pump keep the stock sender. You should have all the PCM and wiring for the engine. If you get the automatic with the motor, you'll have to swap the tail housing on the tranny so you can mount the torque arm.
Not for sure about the raidiator, I used the LT1 radiator and fan setup that was in an f-body as well.
Old Mar 9, 2010 | 09:27 PM
Car: 89 camaro rs
I 'am so pumped about swapping i can not wait. Started the caprice today and heard the v-8 sound, boy did it make me feel good just the sound of more power. So what kind of cam and headers do you recommend? The guy gave me a posi rear end from 1 1994 caprice because the one on the 96 car has a bad bearing. Question is this if the bolt pattern is the same on the cover can i just swap the guts? The steering linkage wont be a problem will it?Any and all information is good information and I thnk you all for helping me line my duck in a row. I will be back on tommorrow night been working ALOT and tired.Once again thank you this is a great site that I'am glad someone told me about.Pictures will be posted when I get the car out of storage and the salt is off the roads dang minnesota winters..
Old Mar 25, 2010 | 08:20 PM
Car: 89 camaro rs
bump..
midge54
Sep 2, 2020 07:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
