How to delete AC in an LT1 Swap
Old Mar 15, 2010 | 10:00 AM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Im hoping to drop an Lt1 into my 91 rs this summer and ive read that some guys have problems when it comes to the AC. I dont ever use my current AC so I dont care to elimanate it of the Lt1 when i put it in . Only Problem is I dont know all that goes into elimanating it of the Lt1. If anyone has done this please let me know how you did it and what parts ill need and where I can find them. Thanks for your help
Old Mar 15, 2010 | 11:00 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Re: How to delete AC in an LT1 Swap
At the least, you can bolt up the AC pump and not use it, OR.. don't bolt it up and buy the AC delete pulley (small cast triangle which bolts to the bracket where the pump would go and there is an idler pulley on it so that you maintain the correct Serpentine belt routing.. Not a big deal to do (least of your worries) .. Likely have to edit the PCM to remove the AC stuff so it won't throw a code but car will still work fine with the light on. (I'd go the extra step and get rid of all the AC stuff and run a cleaner engine bay though) ... Myself I want the AC and I'm struggling on how to get the lines routed so I can avoid burning them on the headers. It's a tight fit!
Old Mar 15, 2010 | 01:06 PM
Pocket's Avatar
Car: 91 Trans Am
Use the delete pulley for a non-AC swap. Youd need to clearance the K-member to mount the compressor, even if its just used as and idler
AC doesnt need to be turned off in the PCM, just dont connect the AC request wire from the HVAC head unit
Old Mar 15, 2010 | 01:44 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You can use this 1LE AC delete e pulley:
http://cgi.ebay.com/ebaymotors/1LE-A...Q5fAccessories
Old Mar 16, 2010 | 05:50 PM
Engine: 383 stroker
will this pulley work with say a 95 or newer vette lt1?
Old Mar 16, 2010 | 06:16 PM
Pocket's Avatar
Car: 91 Trans Am
Probably not because the C4 brackets are different
Old Mar 17, 2010 | 08:54 AM
Engine: 383 stroker
Well that sucks...anybody know of a company or person that makes them for vette Lt1's
Old Mar 17, 2010 | 06:50 PM
Firebat's Avatar
This is the best LT1 f-body a/c delete bracket you can buy, only because it offers maximum clearance.
http://www.bowersrodshop.com/info_deletepulley.htm
For corvette LT1 a/c, I'm having a hard time finding a LT1 a/c delete pulley.
Old Mar 19, 2010 | 09:43 AM
Engine: 383 stroker
Thanks for the link
midge54
Sep 2, 2020 07:13 PM
midge54
Jan 29, 2017 07:00 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
sreZ28
Aug 14, 2015 07:48 PM
